Quality and Experience Testing
JamesM
Re: Quality and Experience Testing
It's picking up a bit now, I guess all the Man U fans switched off,  Grin
Strat
Fixes: 565
Time 19:24 ADSLMax 8128Kbs Sync
Array
   [0] =>  1  vl7.sec.ptb-gw4.plus.net (212.159.3.25)  0.600 ms
   [1] =>  2  vl427.pih-gw3.plus.net (212.159.1.123)  0.561 ms
   [2] =>  3  gi1-1.ptn-gw01.plus.net (212.159.1.178)  11.467 ms
   [3] =>  4  gi11-0-0-421.ptn-ag04.plus.net (84.92.2.136)  12.172 ms
   [4] =>  5  xxxxxx.force9.co.uk (80.229.xxx.xxx)  25.957 ms
You are currently connected to the gateway known as ptn-ag04.
Pre-game
Time 20:39
Time 21:50
JD Speedtest attached below updating every 15 minutes.
w23
Fixes: 4
Sorry, I did the 'before' tests then didn't manage to do any 'during' thanks to my demanding family!
TBB BQM doesn't look too bad:
Call me 'w23'
198kHz
Fixes: 42
Browsing seemed normal all day.
IP 31.185.48.xxx
Gateway pcl-ag08
IP profile according to BT: 3000. IP profile according to PN: 4000.
speedtest.net results -
Time   Down  Up      Ping    Server
1522   3·17   0·32    94      Skipton
1714   3·13   0·35    84      Lancaster
1921   3·08   0·37    85      Lancaster
2001   2·36   0·36   111      Lancaster
2036   2·39   0.36   111      Preston
2140   1.00   0·37   110      Preston
2152   1·85   0·35   104      Preston
2203   3·01   0·36     96      Preston
2213   3·00   0·34     90      Lancaster
Blip at 9:30am was a Skype session. No idea what happened around 5pm.
BT technician (Retired)
JayG
Fixes: 6
No significant differences to report between before, during, and after the game (ptw-ag02)  Smiley
Strat
Fixes: 565
Sorry couldn't resist...but info is in there
bobpullen
Fixes: 331
I wasn't really using my connection much last night although SWMBO was checking mail on her iPhone until about 10.pm. Shortly after that I started streaming a movie using Sky Go on the XBox (that finished around Midnight).
Just checked my latency graph and the period during the game doesn't look too great ...
Edit: I'm on a Telehouse West gateway BTW (ptw), although my traffic's routed slightly unusually as I'm taking part in a closed technical trial at the moment.
Anotherone
Champion
Fixes: 21
Sorry about the delay in collating my info - too many balls in the air. Didn't have time to run any elaborate tests Monday evening, had other things SWMBO needed doing so wasn't using the Internet much but here's my experience for what it's worth (Sorry, forgot to run that first test again) - Copies of BBC Diagnostic tests attached.
pcl-ag02 (20CN)
1st BBCnorm.jpg is what I typically get when there is no congestion.
2nd BBC1942.jpg test was run at 1942, cmd prompt ping to bbc.co.uk was OK typical result
3rd BBC2022.jpg test was run at 2022, major slowdown but cmd prompt ping ok! but overall result bad
4th BBC2024.jpg repeat of previous to check consistency, still bad, but cmd prompt ping to bbc.co.uk was ok but overall result bad.
TBB speedtest at 2029 gave 0.9Mbps, a more typical result is about 6Mbps  - bad result.
TBB speedtest at 2030/31 gave 0.7Mbps yuk! however the BT Beta test gave speed ~6.2 but a ping of 2683ms - never had a figure anywhere near as bad.
What browsing I did, I noticed a slow down in page loading 2030-2100 ish.
5th BBC2300.jpg at 2300 almost back to normal.
