Problem with HTML on [s]Bandwidth[/s] portal pages
Fixes: 246
See http://www.plus.net/support/service/network_performance/broadband_bandwidth_usage.shtml
On looking at the page this afternoon, I see "VAT" rendered in the top left hand corner.
Inspection of the HTML code shows spurious text in the HTML source in the <head> section - see line 45
   <script src="/assets/menus.js" type="text/javascript"></script>
   <script type="text/javascript" language="javascript" src="/assets/business_custom.js"></script>
   <script type="text/javascript" language="javascript" src="/assets/jquery/thickbox/thickbox.js"></script>
   VAT
   <script type="text/javascript" src="/assets/sifr.js"></script>
   <script type="text/javascript" src="/assets/sifr-config.js"></script>
   <script type="text/javascript" src="/assets/addthis_widget.js"></script>
Browser is IE11 on Win7 64bit
Kevin
26 REPLIES 26
Re: Problem with HTML on Bandwidth page
I can't see it and VAT does not appear in my source view.
Windows 8.1 x64 Waterfox (x64)
Mook
avatastic
I don't see it on the page or in the source.
Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/38.0.2125.104 Safari/537.36
F9 member since 1999
F9 ADSL customer since 2004
F9 FTTP customer since 2024
ejs
Aspiring Hero
Fixes: 25
I expect the problem depends on what kind of account you're logged in with - based on the presence of business_custom.js.
Fixes: 246
ejs,
As every an interesting "take" on the problem... causing me to go back and do some checking!  Wink Cheesy
I can now report that the problem is more widespread that the broadband usage page and is present when NOT logged in.  This is the HTML from http://plus.net
<script type="text/javascript" language="javascript" src="/assets/jquery/latest.js"></script>
<script type="text/javascript" language="javascript" src="/assets/jquery/plugin.cookie.js"></script>
<script type="text/javascript" language="javascript" src="/assets/jquery/member_centre/member_centre.js?refresh=140410"></script>
VAT
<script type="text/javascript" language="javascript" src="/assets/custom.js"></script>
<script type="text/javascript" language="javascript" src="/assets/jquery/liveperson/mtagconfig.js"></script>
<script type="text/javascript" language="javascript" src="/assets/jquery/liveperson/liveperson.js"></script>
On further testing I can advise that this problem is NOT SEEN when LOGGED IN to the member centre.
    <script type="text/javascript" language="javascript" src="/assets/custom.js?refresh=25092012"></script>
    <script type="text/javascript" language="javascript" src="/assets/jquery/member_centre/member_centre.js?refresh=25092012"></script>
Kevin
MauriceC
Resting Legend
Fixes: 17
Re: Problem with HTML on [s]Bandwidth[/s] portal pages
Stepping back before @Townman last post.
I don't see VAT rendered on the screen, but I do see it in the source in FF32 and FF33 both on a Widow's XP system.  As expected, I see quite a different set of source in IE8 but NO VAT.
It's not critical, but the answer as to Why? and How? could be intriguing.
Maurice
ejs
Aspiring Hero
Fixes: 25
If clearing the browser cache doesn't change anything, perhaps try with all browser add-ons disabled.
Fixes: 246
@ejs,
Clearing the cache is not overly desirable (impacts other site use) and does not aid identifying the cause of the issue, though I agree it might eliminate the issue for me.
Quote from: MauriceC
Agreed, one wonders what functionality is being masked here?
I've run the log on page under IE diagnostics - there are a number of errors and an access forbidden error.
SCRIPT7002: XMLHttpRequest: Network Error 0x80070005, Access is denied.
File: index_nlp.html
Running the BB gateway page under diagnostics, I saw access forbidden on sh21.html in addthis_widget.js
I then ran the page up using PRIVATE browsing and did not see the error.
I now suspect that there is something in cookies for PN portal which the server is not handing correctly.  If someone from PN can identify the cookie concerned, I can see about exporting to the development team for inspection.
Kevin
ScottStorey
I'm having trouble replicating this myself and I'm not seeing it rendered or in the source.
Unfortunately my VPN appears to be down (i.e. I've clearly forgotten the password) so I'm not able to check with one of our test business accounts.
I have a "volunteer" in mind to investigate if he is not too busy, I'll have a word with him tomorrow.
Fixes: 246
Hi Scott,
Good to see you back around here.
"Volunteer" you make it sound more like "victim" - I guess this is going to be a code inspection job... "What is done different at this point server side for not logged in access?".  Good old fashioned code desk checking - everyone had better be looking busy!  Cheesy
There is the possibility that this is not in the source but has been pulled from the cookie - note (after following Andy's advice) i do not see it in private mode browsing, which I presume means you cannot see any stored cookies?
Kevin
bobpullen
Fixes: 330
Quote from: ejs
Logged into Kevin's account using IE 11 on a Windows 7 x64 machine and I was unable to replicate the problem, no reference to VAT in the source of this page whatsoever.
Same applies when I'm logged out.
Fixes: 246
Hi Bob,
Was it you who got "volunteered" by Scott?
I did ask if it could be cookie content related?  I still see the issue (just checked) - if someone can tell me the cookie details to look for I can get it and save it, then delete it and see of the "problem" goes away.
Armed with that information and the cookie your devt guys can desk check the code!
Cheers,
Kevin
behaviourneeds
I see it also when logged in.
See the attached image.
Chris
bobpullen
Fixes: 330
What cookies do you both have that contain 'Plusnet' or 'plus.net' in the file name/content? I only checked briefly after trying to replicate the problem and there were these five. I don't use IE11 so locating the portal specific ones is likely to be much easier for me. I imagine it becomes a little trickier when considering other Plusnet sites under the same domain such as this one.
plusnet.tt.omtrdc.net/m2/plusnet
plus.net/
portal.plus.net/
webstats.plus.net/
www.plus.net/
MauriceC
Resting Legend
Fixes: 17
I see the same image as  @behaviourneeds
WIN XP Pro 32bit  FF 33.0
Maurice
