Problem sending free-online emails
gray77
Re: Problem sending free-online emails
Thanks for letting me know. I’m very new to using the forum and had not realised.
I’ll make sure to use private messages for posting such information in future.
pvmb
Aspiring Champion
Fixes: 14
@pvmb wrote:
@gray77 wrote:
BUT a new development today - now I can't login to Plusnet  Webmail at all. Yesterday I logged in as normal but today the login fails......????Huh
Webmail has been very up and down over recent weeks. Likely caused by the ongoing work to transfer to Greenby?
Yep!
"Please be aware that Webmail may be slower than usual while migrations are in progress."
"We have temporarily disabled the sort function, there is no need to contact us."
gray77
Yes it is very slow and REALLY annoying!
If your having the same problems as me try the Roundcube app below - seems to work better
https://webmail.enmail.co/
gray77
If anyone is having problems with their free-online email account this might help.
My emails using Thunderbird mail client had worked perfectly for over 10 years but suddenly in mid October I was unable to send emails.
I searched around on the forum and internet and eventually changed the outgoing server  settings in Thunderbird from  relay.free-online.net  to  relay.plus.net  This solved the problem.
Then a few weeks later, very suddenly, literally overnight, I was unable to receive emails. All was normal on 4th November but on 5th November onwards no emails were received.
I then spent several days trying various settings in Thunderbird, including changing the incoming server to  mail.plus.net  but nothing worked.
Finally, more by luck than judgement, I went back to my original settings with  mail.free-online.net  as the server andjust changed the user name to my email address- and that did it!! Thunderbird then proceeded to down load 576 emails!!
I’m reluctant to call this a permanent fix because as these problems occurred  so suddenly in the past few weeks I fear it may happen again - I’m convinced all these problems are due to the Greenby migration.
Very disappointed that Plusnet did not inform their customers they needed to change their email settings - surely someone must have known this would happen. “We’ll do you proud” the logo says  - but not in this case!
BTW Plusnet Webmail is very unstable and erratic at present.The Roundcube Webmail is much better
Just login with your email address and usual password.
plusnettony
Fixes: 64
It's concerning that you needed to change your settings, as the idea was that you didn't need to. I will keep an eye out for this though for other users.
 Tony T
