Problem Reporting
Fixes: 479
Problem Reporting
I have just read this:  https://community.plus.net/t5/Service-Information/How-to-get-help-with-your-service-during-the-bad-w...
I know that the text phone fault reporting is up and running. I really hope that this is also introduced as a permanent way of reporting broadband faults, not just for the current bit of bad weather.
If it works as promised it would certainly lift the reputation of Plusnet customer services.
4 REPLIES 4
Fixes: 387
Re: Problem Reporting
Might save those of us Community members who try to help some grief as well.
Fixes: 1,662
Cheers for the feedback @Baldrick1
This has actually been the case for quite a while now. I can't remember how long though. We've got this way of reporting a fault documented as a help & support article here: https://www.plus.net/help/report-a-problem/
I've copied & pasted the relevant content into the service status rather than link to that article, to make it easier to read.
Also, if you ring us on 0800 432 0200 from a mobile and select the option that suggests you have a problem with your service, we'll text you automatically you can reply to, even before you're put through to an adviser.
Fixes: 479
@Gandalf
Thanks, I had never spotted this service. Things are on the up!
As @jab1  says,, now we know it’s there we can point others to it.
Fixes: 1,662
@Baldrick1
Yep absolutely.
I'm told for the majority of texts into the faults automation tool, they're handled automatically without adviser contact.
In the case of we can see a service outage logged for a particular line so we don't need to raise a fault or further checks to be carried out, we'll test the line and text back the current estimated resolution date we've got from suppliers.
