Postcode address lookup
- Feedback
- Plusnet Feedback
- Postcode address lookup
31-03-2012 11:28 AM
This problem is not exclusive to Plusnet but I wonder if they could advise their post code look up provider of this issue?
Re: Postcode address lookup
31-03-2012 12:08 PM
31-03-2012 12:20 PM
Most address search utilities have configuration options that define how the address is presented - it's not impossible that PN have misconfigured it.
31-03-2012 12:24 PM
"You have used up all your searches for today, Sorry. "
31-03-2012 12:28 PM
Quote You can still do 15 more searches today.
http://postcodefinder.royalmail.com/popups/limit.aspx
31-03-2012 12:35 PM
31-03-2012 12:43 PM
Edit: You might need this: https://addons.mozilla.org/en-US/firefox/addon/cookies-manager-plus/
31-03-2012 12:50 PM
31-03-2012 1:20 PM
31-03-2012 1:28 PM
Quote The scaffolding was put up on a property in Windmill Close in Barkway, Royston. However, this was the wrong Windmill Close. The correct address was situated just 8 miles away, in Bassingbourn.
Both streets have an SG8 postcode, yet Google maps and a number of digital maps, including sat-nav maps, reportedly show the newly built road when the older one is searched for.
31-03-2012 5:39 PM
I was checking out another provider who were unable to connect me because my postcode gave the wrong address and they reckoned there was nothing they could do. Pah!
So I checked it out myself. There appears to be more than one list. Royal Mail has it right, but the other one - whatever that is - was referring to a line of houses that haven't existed for at least 15 years -- there is now a block of flats.
All this was well for me because I ended up with PN instead of the other bunch of twicers....
01-04-2012 7:46 PM
Quote from: thedux This problem is not exclusive to Plusnet but I wonder if they could advise their post code look up provider of this issue?
Any of the decent postcode lookup solutions out there use data derived from Royal Mail's PAF, and I can't really see Plusnet using anything else tbh... (I could be totally wrong, and I'd love to hear Plusnet's input on this!)
Quite a lot of address elements are considered to be postally non required by Royal Mail, so if you search for your address using the link above and your village doesn't come up there, then you'd really have to take this up with RM instead of Plusnet... (I would advise complaining about it anyway if you're getting someone else's post!)
