Portal Down? (Cannot login)
mancmackem
Keeps saying wrong username and password, but it is exactly the same username and password I use for the forum.
Has worked as I have raised a ticket and would like to check it.
Is the portal down?
3 REPLIES 3
Oldjim
Resting Legend
Fixes: 63
Re: Portal Down? (Cannot login)
They aren't necessarily the same
For the portal you should use the username and password as in your router when you are connected to Plusnet servers
mancmackem
You're right Jim! But I'm sure I've managed to log in with just the handle and selecting plusnet from the dropdown.
But 99% it is me being a fool!
Thanks pal.
Pettitto
Fixes: 5
Sorry for the delayed response here, are you able to log in okay now?
