Plusnet Protect
- Feedback
- Plusnet Feedback
- Plusnet Protect
Plusnet Protect
23-06-2016 5:32 AM
Just to let you all know. Plusnet Protect will not install. I heard yesterday that there are problems but as a very new member of Plusnet I could not find any information about the problem on the forum. After ringing the help line I was told it is being sorted out but will not be available until sometime next week.
Re: Plusnet Protect
23-06-2016 6:01 AM
There are plenty of other free AV security software about ,, as mr Google ![]()
Plusnt protect is not one of the better ones ![]()
Re: Plusnet Protect
23-06-2016 1:08 PM
Hi Rongtw,
I currently use Comodo free firewall and Avast free antivirus. However the McAfee internet security although free with Plusnet it is the full blown paid version. My thoughts were give ita try. I am surprised you say there are better free AV out there. McAfee is internet security not a free AV.
Re: Plusnet Protect
23-06-2016 1:21 PM - edited 23-06-2016 1:23 PM
and its results are fairly horrible compared to almost every other option
Re: Plusnet Protect
23-06-2016 1:48 PM
As Jim says PN protect is bad Macafee ,,,,,,,,,, Ok yes its full version But they giving it away for FREE !! ![]()
Re: Plusnet Protect
23-06-2016 3:02 PM
I think that you do better with your present setup, rather than adopting the PlusNet McAfee product.
However, if you do want to try it then you will need to completely remove your present Avast (and probably the Comodo firewall as well, I don't use the package) before the new product will function properly. By completely remove, I mean running the Avast clean-up product after deleting through the Control panel. And, if you do install and want to go back to Avast, then you will need to run a complete uninstall using the McAfee clean-up tool.
Re: Plusnet Protect
24-06-2016 12:09 PM
Yes, I will keep my existing setup which I have had for several years. Thanks for your feedback.
ianshere
Re: Plusnet Protect
24-06-2016 1:51 PM
Not sure if my post will reach all who responded to this topic, as you can see I am Newbie, but many thanks to you all for your responses.
