Plusnet Premium Estimated line speed
- Feedback
- Plusnet Feedback
- Plusnet Premium Estimated line speed
03-12-2009 12:02 PM
At the start of this month i switched from a monthly contract to Plusnet Premium. Before i was getting a stable 6.5mbps but now i am only getting around 1.8mbps. My current line speed has dropped from 7150 to 2000. Is this normal when switching or will i now onlt get these speeds? If so i wish i had not switched over.
I did a check at http://speedtester.bt.com/ and these were the results. Seems i should be getting faster than i am currently getting..
Download Speed
1710 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 1710 Kbps
Additional Information:
Your DSL Connection Rate :8696 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Download Speed
1710 Kbps
0 Kbps 7150 Kbps
7 REPLIES 7
Re: Plusnet Premium Estimated line speed
03-12-2009 12:06 PM
Welcome to the Forum mPH.
What is your Plusnet Profile here https://portal.plus.net/my.html?action=stable_rate
03-12-2009 12:12 PM
Come on Strat, do you really need to ask? We both know it will be 2000!
03-12-2009 12:35 PM
Just gathering documentary evidence for a conviction John
03-12-2009 12:42 PM
Indeed the profile had dropped to 2000 due to a problem we are investigating during the account change. I've upped this to 7150 to match the BT IP Profile.
03-12-2009 12:44 PM
@mPH
If your speeds haven't returned you may need to disconnect/reconnect.
03-12-2009 2:24 PM
Quote from: Chris Indeed the profile had dropped to 2000 due to a problem we are investigating during the account change. I've upped this to 7150 to match the BT IP Profile.
Yes thank you that has sorted it!!! Disconnected and reconnected now, and all back to what i was getting before, but with better Ping for some reason (not complaining though) Thanks for the quick response!
04-12-2009 10:01 AM
No problem, glad it's sorted now for you.
