Plusnet Premium Estimated line speed
mPH
At the start of this month i switched from a monthly contract to Plusnet Premium.  Before i was getting a stable 6.5mbps but now i am only getting around 1.8mbps.  My current line speed has dropped from 7150 to 2000.  Is this normal when switching or will i now onlt get these speeds?  If so  i wish i had not switched over.
I did a check at http://speedtester.bt.com/ and these were the results.  Seems i should be getting faster than i am currently getting..
Download  Speed
1710 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 1710 Kbps
Additional Information:
Your DSL Connection Rate :8696 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
7 REPLIES 7
Strat
Fixes: 565
Re: Plusnet Premium Estimated line speed
Welcome to the Forum mPH.
What is your Plusnet Profile here https://portal.plus.net/my.html?action=stable_rate
jelv
Fixes: 10
Come on Strat, do you really need to ask? We both know it will be 2000!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Strat
Fixes: 565
Just gathering documentary evidence for a conviction John Wink Smiley
Chris
Legend
Fixes: 169
Indeed the profile had dropped to 2000 due to a problem we are investigating during the account change. I've upped this to 7150 to match the BT IP Profile.
jelv
Fixes: 10
@mPH
If your speeds haven't returned you may need to disconnect/reconnect.
mPH
Quote from: Chris
Yes thank you that has sorted it!!!  Disconnected and reconnected now, and all back to what i was getting before, but with better Ping for some reason (not complaining though)  Thanks for the quick response!  Smiley
Chris
Legend
Fixes: 169
No problem, glad it's sorted now for you.
