Plusnet IRC Server
Dom
Re: Plusnet IRC Server
Not sure what the crack is, but I'm back on now without any problems. Not sure what happened.
jelv
Fixes: 10
Quote from: fourfourdevon
Quote from: adiewoo
Calling would be no good, as it's part of PUG and not a supported service.
Oh... I never realised there were any such services...
So you'd never read adiewoo's signature?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
avatastic
Who is adiewoo?
F9 member since 1999
F9 ADSL customer since 2004
F9 FTTP customer since 2024
Strat
Fixes: 565
dvorak formerly known as adiewoo
jelv
Fixes: 10
[me=jelv]goes to check the forums rules - OK let you off adie, you've changed them![/me]
generic
is it possible to connect to this from a non plusnet IP?  Other ISPs seem to get along fine without this restriction (and surely you're most likely to want to access the server when your plusnet connection is down!?)
Anyway, if it's any use, my non plusnt IP is static if you are able to whitelist IPs?
jelv
Fixes: 10
http://usertools.plus.net/irc/ works from a non-Plusnet IP
generic
hmm.. I like to lurk Smiley
matt_2k34
Lurking is good Smiley
The IRC server doesnt get that much use sadly.
the IRC whilst having staff in at times, a) isnt always active b) isnt "official" route of support, even if support is given in there..
The IRC is restricted due to previous abuse IIRC. I dont expect that to change. Smiley
Regards
generic
Bah, oh well.  For what it's worth, AAISP (currently 169 users in #A&A) and Be (currently 84 users #be) both manage just fine with open channels.
[me=generic]shrugs ;)[/me]
matt_2k34
But, theyre used as a way of supporting their customers.
This IRC sometimes goes full days without anyone as much as entering / chatting... =P
Feel free to bring people over though. And there is nothing to "stop" a user from bouncing their connection through a plusnet connection to connect to PN IRC.
Infact, the latter is quite common, particularly with people whom have stopped using plusnet, yet have come to know some of the regulars. Smiley
Regards
reddev87
Is the server down? Can't seem to connect.
matt_2k34
Nope, not at all although its very inactive!
connecting to usertools.plus.net:6667 i assume?
Theres a list of methods in the link in my sig Smiley
(obviously, the connection will only work from your broadband, so dont try over your phone 3G etc..)
Regards
reddev87
Ok, i think I may know why I can't connect.
My PN IP doesn't seem to have a xxxxxx.plus.com hostname, and since its limited to PN connections, Im going to take a wild stab in the dark and say im being blocked from connecting.
CGI connects fine, but it works from non PN connections.
matt_2k34
That is correct.
Check your messages! (in just a moment :P)
Regards
