PlusNet "ask a question"
timsmith
Re: PlusNet "ask a question"
Sorry - the original screen shot didnt show the bottom. IVe attached a new one. Its just not there!
Strat
Fixes: 565
I have just tried it in IE and as you say Timsmith it doesn't show.
So it's ok in Firefox and Chrome but not IE Undecided
Microsoft strikes Again Angry
timsmith
Strat,
Thanks for the troubleshooting -  I havent got Chrome or Firefox available on my work laptop to check.
Tim
adamwalker
Fixes: 223
Its back to the problem tool for me then! (that's what we use to log issues, not a derogatory name for one of my colleagues!) Cheers guys, keep you posted.
 Adam Walker
Strat
Fixes: 565
You're welcome Smiley
Andrew_B
Thanks for bringing this up, we're investigating now.
To aid with that.. what version of IE are you uys using? (Help >> About Internet Explorer)
If you're using IE8, does switching between compatability and normal view affect the problem?
adamwalker
Fixes: 223
FAO strat and timsmith,
Can we also ask you a quick favour and click this link here http://www.plus.net/hostname.php and report back what you see. This will let us know what portal server you are hitting when you try to do this.
 Adam Walker
Strat
Fixes: 565
Portal14
timsmith
Portal 11.
Andrew_B
Quote from: Andrew
Quoting since you both missed my post Smiley
Strat
Fixes: 565
Sorry Andrew I was about to post Embarrassed
IE7
EDIT: However it works fine in IE8.......(just installed).
adamwalker
Fixes: 223
Thanks Strat,
I've let Andrew know. FYI this is now being handled as a P1
 Adam Walker
timsmith
Yep - Im on IE7 as well.
Andrew_B
Hi guys, thanks for the information.
This problem should now be fixed.
We found that the problem was apparent with both IE7 and IE8 (when using compatability view).
Strat
Fixes: 565
It certainly looks like it Smiley
Thanks guys.
