PlusNet "ask a question"
- Feedback
- Plusnet Feedback
- Re: PlusNet "ask a question"
- « Previous
- 1
- 2
- Next »
14-09-2010 12:21 PM
14-09-2010 12:42 PM
So it's ok in Firefox and Chrome but not IE
![Undecided Undecided](/html/@0D61218B4C14ADFBC10BECD1C628E66A/images/emoticons/undecided.gif)
Microsoft strikes Again
![Angry Angry](/html/@5CA762C7B9B1D4AB36AAB959133ED0B4/images/emoticons/angry.gif)
14-09-2010 1:21 PM
Thanks for the troubleshooting - I havent got Chrome or Firefox available on my work laptop to check.
Tim
14-09-2010 1:41 PM
14-09-2010 1:44 PM
![Smiley Smiley](/html/@104CD63F9302A50EF5EC70FE32BB8AA1/images/emoticons/smiley.gif)
14-09-2010 1:57 PM
To aid with that.. what version of IE are you uys using? (Help >> About Internet Explorer)
If you're using IE8, does switching between compatability and normal view affect the problem?
14-09-2010 2:11 PM
Can we also ask you a quick favour and click this link here http://www.plus.net/hostname.php and report back what you see. This will let us know what portal server you are hitting when you try to do this.
14-09-2010 2:11 PM
14-09-2010 3:19 PM
14-09-2010 4:11 PM
Quote from: Andrew Thanks for bringing this up, we're investigating now.
Quoting since you both missed my post
14-09-2010 4:23 PM
![Embarrassed Embarrassed](/html/@39CAA4D3C5337609D22BCCF670FC8D42/images/emoticons/embarrassed.gif)
IE7
EDIT: However it works fine in IE8.......(just installed).
14-09-2010 5:11 PM
14-09-2010 8:40 PM
15-09-2010 9:13 AM
This problem should now be fixed.
We found that the problem was apparent with both IE7 and IE8 (when using compatability view).
15-09-2010 9:44 AM
Thanks guys.
- « Previous
- 1
- 2
- Next »
