PlusNet and Safe Surfing/Web Filtering
Kevin4President
I have two PCs, a laptop, a notebook and several smartphones all on our home network. I would like to be able to activate Safe Surfing/Web Filtering/Parental Controls on what sites are accessible. With so many devices I don't want to do this on each device - I just want to switch it on on the router or at PlusNet. But unlike some ISP's, PlusNet does not have a Safe Surfing setting. I have the default PlusNet router. This does have some filtering, but I have to manually setup permitted and banned websites - and given the hundreds that I use, I can't possibly do that manually. So come on PlusNet, please let's have a Safe Surfing option that we can switch on your end. Any plans for one? Would any other users want this? Please let me know. I appreciate this won't be 100% effective. But something is better than nothing.
5 REPLIES 5
orbrey
Re: PlusNet and Safe Surfing/Web Filtering
While there are no plans currently I've made sure that this idea will received internal visibility, we'll certainly update you as and when we get any progress. Please don't expect anything particularly soon though, I'm afraid the development of new tools can take a long time. The more support that's added here though the more likely it is that something will happen Smiley
Fixes: 1,495
You can have a look at OpenDNS, change your DNS on your router and you can filter out a lot of sites.
jelv
Fixes: 10
... which can be very, very easily bypassed by changing the DNS settings on the PC.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
MauriceC
Resting Legend
Fixes: 17
Several devices / services have been tested in the past - but none of them (sadly  Embarrassed )  were deemed good enough to put into service.
Perhaps there is now a better product that CAN  defeat the very Savvy teenagers AND be easy to manage AND not dominated by USA based data?
I remain optimistic  Cheesy
Maurice
samo
Hi
Can I just add my vote here for any tools / functions to do a central parental control. Like others here we have a plethora of devices (none of which have Windows O/S) and it's not feasible to block the "savvies"
I appreciate that nothing's coming soon but the more voices....
Cheers
Samo
