Plus Net Can't Find Me, Can't Connect Me.
Frustratedme
After getting fed up with poor service from Sky, I decided to change my line, calls, and Broadband to Plus Net.  Checked online, great, I can have fibre in my area AND they had a special offer on.  So I tried to sign up.  Oh dear.
I don't have a house number, only a name, but they have spelt it wrong.  Every time I tried to correct it, their website threw me out and sent me back to the beginning again.  Eventually a Plus Net call agent rang me, so I told her the problem.
She told me she had fixed it (really?) but I can't have fibre!  I told her it is available on the checker, my next door neighbour has it and we're fed from the same pole.  No sorry, not available.  I gave up.
I checked again online - my house is still misspelt, and fibre is still available. But as soon as the spelling is corrected, fibre is not available.
So I haven't signed up with Plus Net.  If they can't get my address right, and they don't know whether I can have fibre or not, they are no better than Sky.
11 REPLIES 11
Fixes: 246
Re: Plus Net Can't Find Me, Can't Connect Me.
A warm welcome to the forums.  This is frustrating ... it is a not that uncommon issue and usually relates to BT's records being wrong (not the ISP's).
Try taking a look here - https://www.btwholesale.com/includes/adsl/adsl.htm?s_cid=ws_furls_adslchecker - just put your postcode in and see what address details BT WHOLESALE has on record for your address.  If your spelling does not match what is here, you are never going to be able to order.
To fix this the current tags owner (Sky) will need to get BT to fix the issue ... unless @Gandalf can apply some wizardry.
Frustratedme
The BT postcode checker identifies my address correctly.  I cannot understand why Plus Net cannot do it.
Fixes: 246
The BT Wholesale checker provides the correct details. That does not mean that BT Openreach has the correct details.
I suggest that you send a PM to @Gandalf with your address and phone number details so that plusnet support can check out the backend systems.
Fixes: 1,662
Hi there.
I agree with Townman. If you can PM me both your incorrect and correct address I can look into this.
Fixes: 1,662
Just to post back here @Frustratedme
Searching your correct address at www.dslchecker.bt.com brings up no records at all, but your incorrect address does.
When the sales adviser had "fixed it" it's likely they've added it as a new address via the signup journey at www.plus.net, but as DSL Checker doesn't recognise your correct address we won't be able to actually order broadband until the line is installed.
So there's 1 of 2 options. Either ask your current provider to submit an ORDI [OpenReach Data Integrity] robot to amend the records on the Openreach database. Or signup at the incorrect address and when the service is provided/you're online we'll then be able to submit the ORDI ourselves.
I hope this helps and makes sense?
Fixes: 246
@Gandalf,
The wording in this response seems inconsistent...
@Gandalf wrote:
Searching your incorrect address at www.dslchecker.bt.com brings up no records at all, but your correct address does.
... but as DSL Checker doesn't recognise your correct address we won't be able to actually order broadband until the line is installed.
Fixes: 1,662
Just edited my post Smiley
(I need a holiday)
Fixes: 246
Anoush,
It seems like only a few weeks since you had one ... but you insisted in logging in here to help people through most of it.
Further observation ... this sounds like a new line install approach ... rather than taking over the existing line ... potentially giving rise to line / service termination fees?
Fixes: 1,662
Yeah as it stands if place an order at the correct address, since there’s no records it’ll go to a new line install. I don’t recommend this option.
Ideally, the records need to be updated by the existing provider first. Or, we place the order at the “incorrect” address then amend records ourselves when complete.
MauriceC
Resting Legend
Fixes: 17
Did this ever get resolved @Gandalf   Faulty or out of date BTOR / BTW  records causing serious grief for both customers and ISP's has become a BIG issue with Migrations; upgrades to Fibre etc yet seems to have little priority for resolution within BT.
Fixes: 1,662
I never heard back from the OP.
