Please reverse the recent PN Profile management on FTTC......
- Feedback
- Plusnet Feedback
- Please reverse the recent PN Profile management on...
09-11-2012 12:20 PM
Since the recent changes we now have to allow for PN changing, or rather not changing all the time their profile to match.
What happened to the 37, 20 and 40 profiles??? Surely we only need one 'regulator profile'.
Granted this seems to be a BT issue but as it's well known why did PN elect to attempt to follow?
One again my sync and BT profile went up days ago to 38.67 and I'm still stuck on a PN profile of 33.8.
This results in me whingeing
I know that if I pop onto Twitter and use the CSC bypass some kind gent/lady would do this instantly but seems a bit wrong..
Regards,
Pete
Re: Please reverse the recent PN Profile management on FTTC......
09-11-2012 12:23 PM
09-11-2012 12:49 PM
I probably will, but it's the 'why did they implement it' that I'm trying to raise the proifile of - if you'll excuse that pun
Call me a cynic but I'm guessing as an underpaid mod you'll get some perks in getting your tickets looked at a little quicker...
Better run and hide now as CSC may not appreciate my humour there
Pete
09-11-2012 12:52 PM
Jim is a volunteer and does not work for Plusnet - He is a customer just like you.
09-11-2012 12:55 PM
As I understand it, Plusnet's traffic management systems need to know the profile for their prioritisation methods.
As an example: If you are streaming a movie which requires, say, 5Mbps and at the same time torrenting a bunch of Linux ISOs, then the Plusnet "end" of your connection needs to know how many packets to send to you before your line is considered "full". If your connection is only 6Mbps, then it knows that at any point in time your streaming will take priority and you'll be left with 1Mbps with which to torrent with.
Without this figure, the Plusnet hardware would just keep sending you data as fast as it can. Thus, your 'prioritised' streaming movie will be competing for bandwidth with your torrent and the end user experience would suffer as a result.
B.
09-11-2012 12:56 PM
I did know that, hence my comment at running and hiding as the CSC wouldn't get my attempt at humour
Point still stands as per original post - why did you implement this extra burden?
Pete
09-11-2012 1:10 PM
Sorry for missing the humour!
I think Barry has pretty much covered the situation above. In the meantime, please do feel free to raise a ticket and our team will ensure that your line is being profiled accordingly.
09-11-2012 1:14 PM
09-11-2012 1:17 PM
I realise the norm for the prifile management etc but this topic was specific to the FTTC product.
From the get go and certainly my 20mths experience on 40/2 and a period on the 80/20 trial there wasn't any automatic intervention on profile from the PN side. It was always manually set to the Max your line product could handle as the BT profile appeared to do all the management work.
There were hiccups with various forms of the static profiles of 37 (the original 40/20 profile) then there was the 'special 20' profile and then we had the 40.
Surely in the 2 years of FTTC it all worked pretty well, hence my curiosity as to why we have a less than perfect situation now.
Ed . Just noted replies from jelv and James.. Thanks
Still curious though as it worked OK before..
Pete
Trying to raise a ticket now but the portal has gone down! maybe James has blocked me
09-11-2012 1:48 PM
Serves you right
Quote from: Cathotel Trying to raise a ticket now but the portal has gone down! maybe James has blocked me
09-11-2012 2:03 PM
09-11-2012 4:30 PM
09-11-2012 4:42 PM
You see, I knew Oldjim throwing the 3 hr ticket response challenge down would work
Many thanks for doing this but I really would like to know the reasoning behind the Profile mechanism change given it's been stable and working as it was for 2 yrs ( ish )
I'm just technically nosey
Is there a way I can change the title of my original thread to make it more discussion related than 'please reverse it'?
Regards,
Pete
09-11-2012 4:50 PM
Quote from: Cathotel Is there a way I can change the title of my original thread...
Go to your opening post and click Modify. Change the title as desired - and for information add an'edit' note at the bottom of the post - then save it.
- Feedback
- Plusnet Feedback
