Please delete
MikeyM
Please delete
My mis-understanding, need the pro package for my needs.
VileReynard
All Star
Fixes: 11
Re: Dissapointed
There's only one 's' in "Dissapointed".
Hope that helps.  Grin
firefly2
Re: Dissapointed
quite right. only one  " s ".... but there are two  " peeeeeeeees.
Roll eyes Roll eyes
MikeyM
Re: Dissapointed
Mand
Re: Dissapointed
You've got a 2500 profile now, what are your line stats (sync, attenuation, and noise margin)?
Value is not recommended for P2P use, as it is managed quite heavily during peak times.
We can look into the modem being faulty, in which case you wouldn't have to pay for it but you do have deferred setup on your account also which would need to be paid up if you do decide to leave.
MikeyM
Re: Dissapointed
Thanks for the reply Mand.
Bt have changed my IP profile to 2000, maybe the plus net profile is stuck again, had that issue before.
I sync just now about 2800 , SNR is 12db, and my attenuation is 53.
It looks to me as though basically I have misunderstood the figures, and got confused with the kbs and kBs thing in regard to p2p.
