PN is a rip off
jelv
Fixes: 10
Re: PN is a rip off
Over 14 hours errored seconds in 15 hours up time! That is not a healthy line!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
monkey001
Re: PN is a rip off
whats the opitions then ?
i would really like to stick with the ping atm but the dl im getting isnt good at all
jelv
Fixes: 10
Re: PN is a rip off
Are you plugged in to the master socket? Have you compared the stats you get if you do?
What I'd like to see is that same page after being connected for an hour when your router is plugged in to the test socket inside the master socket. We need to make sure that there is nothing inside your house that is causing the errors.
monkey001
Re: PN is a rip off
kk ill put it in the test socket as said before it was in there but i got over 0.5mb less dl before interleaving was turned off and it was the same with the ping no change whats so ever and i had BT test the socket im in atm when they came and checked the master socket.
ill post them up in abit
monkey001
Re: PN is a rip off
gone wireless atm and the pages load up alot quicker
error seconds are down massively
gonna have a play around
jelv
Fixes: 10
Re: PN is a rip off
Are those stats with the router in the test socket? If so that is very significant, not that you are wireless (or do you have to use wireless when in the test socket because the PC and router are too far apart?).
Can you describe your telephone wiring, extensions etc and everything that's plugged in to a phone socket please.
monkey001
Re: PN is a rip off
yeah have to use wireless when in the test socket
1 telephone plugged in the test socket with the router and thats it ive changed everything last time and got everything wireless.pulled out the sky pulled out the phone/fax
router normally goes in the other room as said the sync speed was better in there believe it or not lol
filter are on everything and ive got a i plate fitted
thinking maybe i should still leave interleaving off as the ping is around mid and rising then when it was on i was getting mid 40 and rising
pierre_pierre
Re: PN is a rip off
some Sky leads look like they have a filter fitted, but it is not, make sure that that is filtered
monkey001
Re: PN is a rip off
yeah i did have one on just ripped it out altogther just in case it was that
monkey001
Re: PN is a rip off
interleaving is back on
ping is back to being rubbish high 40s and rising
dont know weather leaving the interleaving off was any better?
ill do some speed test and that as the web pages are taking awhile to load up
itsme
Re: PN is a rip off
You /PN/BT have to determine why your error seconds are so high. WAN up time is approximately 14 hours and your error seconds is approximately 12 hours. This is not good.
monkey001
Re: PN is a rip off
payed BT to check the line and sockets and that was fine they said excellent line quality lol and im in the test socket atm so there nothing i can do to make any better i believe
Oldjim
Resting Legend
Fixes: 63
Re: PN is a rip off
Did you reboot the router at the start of this uptime. If you didn't it is possible the error seconds didn't reset - I know mine doesn't
monkey001
Re: PN is a rip off
web pages still take longer to load up then when i was wireless with interleaving off and am always having to retart pages but have full wireless signal
the error seconds are better
gaming wise is worse with interleaving on alot
VileReynard
Fixes: 20
Re: PN is a rip off
Interleaving=16!
Why not try a fixed 2Mbps line instead of MAX?
