PN 24hr support
rongtw
Fixes: 12
PN 24hr support
In view of present circumstances will PN realize that removing 24 hr support is a BIG BOO  BOO  Roll_eyes
What has happened today  surely will not be the only time something similar will happen , PN has not done us proud ! as they now failed to provide adequate support  Angry
31 REPLIES 31
nursemorph
Re: PN 24hr support
I doubt it....they'll just sweep it under the carpet so to speak and sit in their offices pretending everything is fine and dandy....now, if it was related to business users and they were complaining at the lack of 24 hour support, then it would get re-instated within days...as it is, only residential customers are complaining so it just gets ignored as we are not important to the company now or in the future
adie:quote
goldenfibre
Seasoned Pro
Fixes: 12
Re: PN 24hr support
PN must bring back 24 hours support. Otherwise we will known nothing about DNS servers went down all night. Not good!
Fixes: 1,493
Re: PN 24hr support
it shouldn't need customers to there's a problem, I'd have thought there should be sufficient network monitoring to flag this up Roll_eyes
7up
Fixes: 19
Re: PN 24hr support
I must say i'm disappointed with the 'good' and 'honest' part of their broadband claim that keeps being blasted all over my TV.
I didn't even know their 24/7 support had been canned. Seems a bit daft if you ask me.. these outages are always going to happen at some point. Thats the nature of technology - unforeseen glitches happen.
chenks76
All Star
Fixes: 12
Re: PN 24hr support
24/7 support for standard home internet is certainly not something that is required.
issues like the DNS problem don't need reported by customers, networking monitoring will pick those up and action as required.
if your internet requirements need 24/7 support then i'd be asking questions if you were really a home consumer or running a business using a home product.
goldenfibre
Seasoned Pro
Fixes: 12
Re: PN 24hr support
Home support is 12 hours a day
Business support is 24 hours a day
AndyH
Re: PN 24hr support
If you desperately want and need 24 hour support, then there is nothing stopping you for taking a business account.
goldenfibre
Seasoned Pro
Fixes: 12
Re: PN 24hr support
^ Very true! But, I don't need business account as I do have my back up (one is PN FTTC) and other one is (VM CABLE) as I can use both for bonding getting 180Meg down and 29Meg up.
Re: PN 24hr support
I don't see how you can bond these two connections when bonding isn't supported by Plusnet, and I doubt for VM either.
chenks76
All Star
Fixes: 12
Re: PN 24hr support
probably using a linux proxy server or similar.
Re: PN 24hr support
Mmmm, don't think so, you need to present a single IP to the internet and this needs to be done in collaboration with your ISP. But I have my orthopaedic slippers on standby should anyone prove otherwise.
goldenfibre
Seasoned Pro
Fixes: 12
Re: PN 24hr support
Yes it can! Smiley
Proof here:
chenks76
All Star
Fixes: 12
Re: PN 24hr support
Quote from: Mook
you could buy a block of IPs and use those
goldenfibre
Seasoned Pro
Fixes: 12
Re: PN 24hr support
^^ Yep - correct!
