One arm tied?
exporters
One arm tied?
I may be one in a thousand BUT in spite of PN’s efforts and the pleasant people I have had contact with, I still have an inconsistent B/b service.
When pressed, the reply is ‘your fault is still being investigated by our supplier’.  What, since 15/12/09 ?  In this time I can only recall two periods of 5/6 days, when the service was adequate.
Having experienced briefly what I expected when signing up last August, it is more than disappointing to be on, yet again, 400kbps downloads & IP profiles of 500 for the last four days.  Constant drop outs & noise.
On enquiring about BTw’s sense of urgency or willingness to respond to anything that could be their equipment/line, one is left with the distinct impression that PN is operating with one arm tied.
Re: One arm tied?
Hi exporters,
I've picked this up and referred it back to our suppliers with some additional notes. As the ticket update says I'm hopeful there'll be an update this afternoon - I'll keep my eyes open and let you know when we've got that.
sharpyuk
Re: One arm tied?
@Exporters
You are so right.. In these situations it can be so easy to point the finger at the service provider when actually it can be down to the slow response and sense of urgency that BT operates.  Must be even more frustrating for PN, they are getting grilled by customers but unable to do anything.
Apparently BT are suppose to ensure fairness when it comes to dealing with issues, but you can't help feeling that they either do it on purpose so you move to BT or that as a BT customer they move a little faster.
mrmarkus1981
Re: One arm tied?
I appreciate what you guys are saying but at the end of the day we are PAYING Plusnet, so as far as consumers faults go, the buck stops with them.
If someones fault has been ongoing for some time (which in this case it has) i can only think there are 3 reasons why it isnt fixed:-
1. The ticket is at the bottom of the pile.
2. Plusnet arent putting the pressure on BTW to look at the issue.
3. Other people are shouting louder about their problems (see no.1)
exporters
Re: One arm tied?
Matt, thanks for pushing this.  Also for the quick response from the PN team this morning.
I'll hold my breath for BT's skills to identify/sort.
sharpyuk
Re: One arm tied?
@mrmarkus1981
Your point is valid and i do not expect anybody would just sit back and let things happen because its out of PN's control.  Its like when your car needs fixing but the part is not available..  its not the garage who sold you the car, its the the car makers who hold it all up.
It is not acceptable when the level gets to a stupid time scale and yes in those instances it will not doubt be due to the points you raised.  Having worked with BT before, it a huge company with a lot of request and although they do their best every day,  i do feel they are not that worried about customers that are not their own or providers such as PlusNET.
So PN are the supplier of the boardband... but the broadband will not work without the phone line..  Its ok to supply you with water, but if there is no pipe do you blame the guy at the end pumping it Tongue
I am in no way making excuses for PN, i am sure they are far from perfect and from what i read on here they do need to start pulling the finger out re support times.  But i do find that a lot of people are quick to blame them without giving reasonable time to gain a solution or await a fix which is out of their hands.
exporters
Re: One arm tied?
In the hope that Matt/Chris may see this, I posted on my open ticket a report on the BT Engineer's visit earlier today.
Having been absent from house for a week, I came back y'day to find an even worse state of affairs.  BT speedtester d'loads 74kbps & IP profile 135.  Ok, patience I told myself, the BT engineer is due Thursday.
He was thorough, give him his due.  But nothing revealed as to why the line was dropping out & ALL tests showed up perfect, he said.  He inspected BT wiring, replaced their in coming cable junction bx, put an additional filter on it, replaced on Master socket my NationADSL with a BT equivalent face plate, went down the road to check BT cabinet - ALL OK.  Prognosis, "if this does not fix the problem, it is down to BTw, their xchange & your line to the cabinet."
Well, I did not expect to see an immediate rise in speeds but with SNR seemingly stable @ 21/15, bandwidth 448/5404, Attenuation 23/41 [all as BT guys meters & my Thomson] it looks/looked promising.  Oh dear, two drops showing on RouterStats since he left.
Q's what next, please.
Re: One arm tied?
Hi exporters,
Sorry I didn't pick this up yesterday. It looks like you've been online since the engineer left yesterday though I'm not sure if this is down to the extremely low line profile giving a stable connection - I'm trying line tests to check this out but they're failing for some reason which makes me wonder seriously about an exchange fault.
I'll update you as soon as I know what's happening there, should be shortly after lunch.
exporters
Re: One arm tied?
Matt, assume you do not know as yet what is happening?  I keep wondering why BTw are so slow in responding, when it seems clearly to be an exchange problem.
In the meantime, can someone bump up the PN line speed please, which is stuck on 1000 [BT IP shows 4000 since early hours of this morning] and my d/load has been on 860 for three days now.
May just experience some faster speeds for the w/end.
Many thanks
exporters
Re: One arm tied?
Well, THANK YOU, whoever @ PN has pushed the button.
At least d/loads are now back to 3.5megs.  BUT for how long, with drops indicated by RouterStats as below.  This is the worst day I can recall for some time.
What is the next step?  An exchange problem?
Fixes: 71
Re: One arm tied?
Are you sure all of those are actually line jobs, did the router re-sync? Some of them look more like transients where routerstats failed to collect the information from the router (because the router was busy).
David
exporters
Re: One arm tied?
Spraxyt, I'm not certain.
During the period on Friday, whilst Thomson router  & l'top were operational on the desk, no one was in the house using them when these drops were recorded.
I have included another router shot this morning - steady SNR all through from last evening [RouterStats, everything else l'top etc deliberately left on] but seems coincidental, when I opened Firefox @ 7.20am the whole thing goes haywire.  Of interest maybe, Firefox opens with a number of tabs from previous session. Lost DSL from 5152 down to 1344.
Funny figs on router stats as well; atten. 29/51, SNR 13/15.5  Normally these would be 21/44 & 12/25.
Do you think the Thomson router is playing up & should replace with Belkin?
exporters
Re: One arm tied?
PS
Sraxyt, within last 5 mins system has recovered itself & d/load 3.4meg [was <1meg].  Very weird and something somewhere is upsetting things.  Detail below.
exporters
Re: One arm tied?
Very unstable - back down again!
Fixes: 71
Re: One arm tied?
With things changing so quickly one would expect detailed monitoring of the connection by BT to identify something within the two-hour slot I believe they allocate. I guess that needs to be initiated by the faults team. However it does seem suspicious that the problems started to occur when your PC became active again. I wonder if the router/cable is not performing as well as it should?
Trying your Belkin and a different Ethernet cable could be helpful. I think your target noise margin is already on maximum so can't make that worse.
David
David
