Not Impressed
niche99
Not Impressed
Just had Fibre installed. Speedtest 70mbps down 15Mbps Up.
Trying to download a 133MB file over http at 60kbs!
Why are my downloads so slow? I got better download speeds with my old provider BE on an 8Mbps line.
Would appreciate a response.
It still hasn't finished downloading arrrghhhhh!
Now testing LibreOffice http download of 184MB speed 56Kbs 38 minutres remaining! Come on stop traffic shaping my http downloads!
Can't port forward using plusnet router. Predefined rules will assign to my registered device, but my custom rule will not assign to my registered device. The custom rule will appear in the dropdown and is selectable but will not assign when I click Add, what do you have to do to get custom port forwarding to work?
2 REPLIES 2
Kelly
Fixes: 9
Re: Not Impressed
Hi, Niche99.
Please disconnect and reconnect your router and see if that improves your performance?
Kelly Dorset
Ex-Plusnet Jobsbody
adamwalker
Fixes: 223
Re: Not Impressed
Just to add, I would definitely expect a lot better having seen the estimate for your line.
I'd give Kelly's suggestion a go if you haven't already and let us know how you get on, we're happy to help you.
Adam
 Adam Walker
