Network slumbering - running at half-speed
- Feedback
- Plusnet Feedback
- Network slumbering - running at half-speed
25-08-2009 11:43 AM
The Plusnet profile says 5.5Mbps (it hasn't caught up yet)
So a speedtester should give a speed of 5Mbps+ ?
These were all taken at the same time, even if some are showing BST+1, rather than BST
Re: Network slumbering - running at half-speed
25-08-2009 11:47 AM
25-08-2009 11:55 AM
25-08-2009 1:00 PM
This is one of the common issues we're seeing on 21C currently.
BT have acknowledged it as a problem which they're currently working on. It appears to be capacity related at the exchange end.
25-08-2009 2:55 PM
BT are in trouble - my exchange serves a primarily residential area, no office blocks!
Lots of large schools though - currently on holiday, which I would imagine to be heavy internet users.
25-08-2009 2:57 PM
25-08-2009 5:50 PM
ive not been totaly un effected over the past month or 2 i have had 2 spells of bad/ jumpy thoughput that lasted for around 1/2 hours before dis appering
25-08-2009 8:04 PM
Bit similar to the old 20:1 contention product.
25-08-2009 8:08 PM
Quote from: ASBO i wonder if its just because am on a 2500kbps profile any way that i dont see the thoughput problems so many are having .
I don't see any of the issues being reported either with the throughtput or PPP or DLM. I'm also on a 2500 profile.
25-08-2009 8:45 PM
If you put my phone number into http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=26957&s_cid=con_FURL_...
It says:-
- Feedback
- Plusnet Feedback
