Move from BBYW2 to PlusNet Extra info please?
glloyd
If I move to PlusNet Extra from BBYW2 can I keep my web space, inclusive VOIP minutes and fixed IP address?
8 REPLIES 8
Oldjim
Resting Legend
Fixes: 63
Re: Move from BBYW2 to PlusNet Extra?
yes definitely for two of them - I am not sure about the VOIP minutes
Fixes: 585
I moved to Value from PAYG a while ago and kept my Voip minutes.
glloyd
Can any PlusNet staff comment please?
BenTrimble
Re: Move from BBYW2 to PlusNet Extra info please?
You will definitely keep your VoIP minutes but I'd recommend we schedule the change (as opposed to requesting the change through the Member Centre) to ensure things like your static IP are carried over without further charges.
glloyd
If you could please Ben. Next billing date is 4/08.
BenTrimble
Done, with an ADSL2+ regrade on an estimated speed of 12Mbps. Let me know if you don't want the regrade.
glloyd
Thanks Ben. Already been on ADSL 2+ since the trial so updated already.
BenTrimble
We must have just not updated your provisioned product then, nothing to worry about Smiley
