Migration Query
James
Re: Migration Query
I need a beer emoticon Smiley
That's fantastic news!
dogwhisperer
Re: Migration Query
Hi James,
If you lived nearer I would buy you a pint..!
I would say that now the clicking noise has gone we can turn interleaving back off, like you say lets see how it goes over the weekend first.....
I have just done a BT speed test and upload is still low....do we know if this has been uncapped yet?
jelv
Fixes: 10
Re: Migration Query
I'd keep interleaving on for at least a week to make sure things are stable. That way if problems return when interleaving is turned off you will know for sure that your line needs interleaving.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
dogwhisperer
Re: Migration Query
Thanks Jelv,
My thinking is that it was most likely the clicking noise that caused the error seconds and high latency, since I cleaned to connector contacts the noise has gone and ping times have come down....
It would be interesting to see what its like now with interleaving turned off, now that the clicking noise has gone........
James
Re: Migration Query
Upstream on your line is technically uncapped Jim - It may be that it'll improves once BT realise your line is happier.
Absolutely certain that it was the clicking on your line - good job with that.
Don't worry about the pint, I'll just tell my boss you said that he had to get me one Tongue
dogwhisperer
Re: Migration Query
Hi James,
Thanks for your phone call just now......
As you could hear the line is very clear now.....
As you say lets see what happens as the BT equipment should realise at some point the line is fine now....
Many thanks to you and all the other plusnet staff that have helped with all of this, especially Adam.......
Tell your boss to get them all and yourself a very large beer or two........enjoy!
All we need now is an England win tonight.......
dogwhisperer
Re: Migration Query
The ping times went up a bit when the football was on today......
But since then it appears to be improving again......
dogwhisperer
Re: Migration Query
Pings improving further today and this is while a world cup match is going on....
dogwhisperer
Re: Migration Query
Doing a continuous ping test using command prompt I am getting pings of 24ms from bbc.co.uk.......
dogwhisperer
Re: Migration Query
Pings still improving, might as well leave interleaving on for now.....
pcoventry
Re: Migration Query
Hello dogwhisperer,
Please do let us know if you want it changed to Fastpath. This takes about 24 hours to complete.
James
Re: Migration Query
That's a really good ping for an interleaved line...
adamwalker
Fixes: 223
Re: Migration Query
Thanks Jim,
I'm glad to see that all seems to have worked out well in the end here. (Adam grasps the nearest wooden object!) Smiley
 Adam Walker
James
Re: Migration Query
[me=Jameseh]offers his forehead[/me]
dogwhisperer
Re: Migration Query
Hi James / Adam,
Been busy this week so just had chance to check current status.....
Download seems odd, erratic and not getting throughput that I should get, so did a BT speed test and despite my router not loosing sync and had no discons for 166 hrs (since 17th June) my profile has gone down from 3000k to 2000k.....but according to the BT speed test I just done it says my download speed is 2913 which it cannot be with a profile of 2000k......so something is clearly not right......
