Migration Query
dogwhisperer
Re: Migration Query
Hi James,
Since your phone call had another discon......down sync has gone up to 4112 and upload is now 618......so now seems uncapped.......
Snr down is 6db which is what I would expect.....
So I assume the re-set of DLM has happened.....
Is it possible you give me a quick call back, something I forgot to ask you.....ta
dogwhisperer
Re: Migration Query
All seems good still, no discons and kept sync at 4112....just waiting for my profile to go up now from 3000 to 3500 as with my current sync speed thats what my profile should be....
James
Re: Migration Query
Excellent, thanks for that.
How's the upstream?
dogwhisperer
Re: Migration Query
Upstream is still 618.......not quite as good as it used to be, (750ish), but good enough......
With all the BT cappings and restrictions removed I have noticed downloads now download at a constant and consistent speed and not stop and start as before.....
BTW SNR margin has kept at a solid 6db so there doesn't appear to be any noise on the line effecting that....
What are the error seconds like you are seeing for my connection now?......I would expect them to be low.....Rami put some info in my ticket and I saw there was 1 error second.....
James
Re: Migration Query
Very small number (4) on downstream, none on upstream.
dogwhisperer
Re: Migration Query
Thanks James......dare I say it all looks good....... Smiley
James
Re: Migration Query
Please don't do that.
Wink
dogwhisperer
Re: Migration Query
Ok, I take it back and we wait a bit longer.... Wink
adamwalker
Fixes: 223
Re: Migration Query
Jim, in case it helps before you say anything like that again touch this image first Wink
 Adam Walker
dogwhisperer
Re: Migration Query
LOL, Adam,
Done as requested....... Smiley
I will be away for the next few days so will have a look how things are when I come back......
Mackins7000
Re: Migration Query
Dogwhisperer, you absolute legend, I can't believe what you've had to put up with, it'd be like losing a limb having no internet, you have the patience of a saint and you had me in stitches sometimes reading this entire thread which took nearly 2 hours!
I'm glad you got it sorted in the end though.
