Merged Interleaving and Absolute Disgrace
rookey
Re: Interleaving
That is ok let see if it makes any different to my gaming as someone said it can help toward the gaming... Or is there any other suggestions?
Regards
Andrew
James
Re: Interleaving
Ok, that's fine.
Out of curiosity - are you connecting via a network cable of by wireless?  If wireless, does it make any difference if you try using a wire instead?
198kHz
Fixes: 42
Re: Interleaving
Whether it helps with gaming depends on what the problem is. An interleaved line will be more stable, but will have a higher latency - ie greater 'ping' time.
A gamer will normally prefer a non-interleaved line for the lower latency, but the line may not be stable enough.
BT technician (Retired)
rookey
Re: Interleaving
Quote from: Jameseh
Ok, that's fine.
As mention on my other thread the router is no way near the PS3 so i cant really test it as there no phone line..
rookey
Re: Interleaving
I have though about upgrading to the Plusnet Pro Package that seem to aim for gamers but am worried that it would make any different from the Option 2 that i am on now
James
Re: Interleaving
It shouldn't make a great difference with PS3 gaming as the gaming traffic will already be prioritised.
jelv
Fixes: 10
Re: Absolute Disgrace
I've just reviewed your two topics and am now very suspicious that your problems are to do with the fact that you connect to your router wirelessly and that in fact there is nothing wrong with your Plusnet line.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
rookey
Quote from: jelv
Then why have I not had a problem with my wireless gaming for over 4 years why now???
James
It could be anything really.
There could be something that has recently been brought into your area that is causing interference, or something that has developed a fault thats causing exactly the same thing.
If you can't try using a wired connection, you shoulod at least try to use a different wireless channel, such as 5.
pierre_pierre
Re: Interleaving
Quote from: rookey
Quote from: Jameseh
Ok, that's fine.
do we take it that means WiFi Shocked
James
Re: Interleaving
Could you get a long ethernet cable just to make sure?
I appreciate that having cables trailing around is a pain, but if it's just to test and also something that might fix the problem, then I reckon it would be worth a go.
rookey
Re: Interleaving
Quote from: pierre_pierre
Quote from: rookey
Quote from: Jameseh
Ok, that's fine.
Are you saying Gaming over Wifi is bad?
rookey
Quote from: Jameseh
Ok going to try channel 5 and see how that goes
James
Re: Interleaving
Not "bad" as such.
But as you need a solid connection for your gaming with the highest quality signal, you should generally look to a wired connection as that is nopt hampered by any form of interference.
pierre_pierre
Re: Interleaving
if you are a long way from the router and there are wall in the way, you can half you line speed, with an ethernet cable up to nearly 100m no drop
