Merged Interleaving and Absolute Disgrace
- Feedback
- Plusnet Feedback
- Re: Absolute Disgrace
Re: Interleaving
26-01-2009 10:28 AM
That is ok let see if it makes any different to my gaming as someone said it can help toward the gaming... Or is there any other suggestions?
Regards
Andrew
Re: Interleaving
26-01-2009 10:33 AM
Out of curiosity - are you connecting via a network cable of by wireless? If wireless, does it make any difference if you try using a wire instead?
Re: Interleaving
26-01-2009 10:38 AM
A gamer will normally prefer a non-interleaved line for the lower latency, but the line may not be stable enough.
Zen SOGEA 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Re: Interleaving
26-01-2009 10:40 AM
Quote from: Jameseh Ok, that's fine.
As mention on my other thread the router is no way near the PS3 so i cant really test it as there no phone line..
Re: Interleaving
26-01-2009 10:41 AM
Re: Interleaving
26-01-2009 11:04 AM
26-01-2009 11:27 AM
26-01-2009 11:44 AM
Quote from: jelv I've just reviewed your two topics and am now very suspicious that your problems are to do with the fact that you connect to your router wirelessly and that in fact there is nothing wrong with your Plusnet line.
Then why have I not had a problem with my wireless gaming for over 4 years why now???
26-01-2009 11:46 AM
There could be something that has recently been brought into your area that is causing interference, or something that has developed a fault thats causing exactly the same thing.
If you can't try using a wired connection, you shoulod at least try to use a different wireless channel, such as 5.
Re: Interleaving
26-01-2009 12:49 PM
Quote from: rookey
do we take it that means WiFi
Re: Interleaving
26-01-2009 12:50 PM
I appreciate that having cables trailing around is a pain, but if it's just to test and also something that might fix the problem, then I reckon it would be worth a go.
Re: Interleaving
26-01-2009 1:53 PM
Quote from: pierre_pierre
Quote from: rookey
Are you saying Gaming over Wifi is bad?
26-01-2009 1:54 PM
Quote from: Jameseh It could be anything really.
Ok going to try channel 5 and see how that goes
Re: Interleaving
26-01-2009 2:00 PM
But as you need a solid connection for your gaming with the highest quality signal, you should generally look to a wired connection as that is nopt hampered by any form of interference.
Re: Interleaving
26-01-2009 2:01 PM
