Member Centre problems
Luzern
Fixes: 9
Silly really, but I can't get in. Can someone remind me. what follows after my user name? I think I'm using correct detail and password. But!
13 REPLIES 13
Fixes: 387
Re: Member Centre problems
Your ACCOUNT password, @Luzern
Luzern
Fixes: 9
@jab1 I am using the password for the plusnet account, but what form is the login after user?
Fixes: 387
@Luzern The 'User' field is your user 'name' ONLY - no other characters at all.
I.e if you user name is 'Fred', that is all you enter.
Luzern
Fixes: 9
@jab1  Thanks For that,
I filled the forgotten password application in and received an email, where the link led me nowhere obvious.
You've told us that you'd like to reset the password for your Plusnet account.
To do this, please click the link within the email we have sent to the email address we have on your account.
Please note:
Resetting your password will also change the password for your other Plusnet services such as:
 - Your broadband connection password
 - Your default Plusnet email address password
Once you've reset your password, you might need to update your router and email applications too.  Most Plusnet supplied routers will automatically update themselves, but if you need any help, then please take a look at our support pages at https://www.plus.net/help/
If you've got any questions, you can contact our Support Team on 0800 432 0200 (from within the UK) or 0345 140 0200 (from abroad).
Please ignore the email if you have not recently requested to reset your password.
Best wishes,
Plusnet Customer Support
http://www.plus.net/
Email ref: E0145
Plusnet plc
Registered Office: The Balance, 2 Pinfold Street, Sheffield, S1 2GU
Registered in England no: 3279013
VAT No: 245 7193 48
Luzern
Fixes: 9
Throughout I heve found  "
Please try again. Make sure your browser allows cookies, otherwise you won't be able to log in." despite allowing all cookies, and making dsl.plus.net permanent.
PLusnet speechless
RealAleMadrid
Fixes: 68
@Luzern What do you mean by "making dsl.plus.net permanent"
The member centre only needs your username and password to login.
Your router needs [email protected]  and password to connect.
There seems to be some confusion here.
Fixes: 387
OK. I'm a little confused now. When was the last time you logged into your account?
If you haven't changed any passwords - don't
To log in to your account, the top box needs your USER NAME only - If you have a PN email address it will be in the form of ' XXX@username.plus.com' -top box.
The password will be your account password which you selected when joining PN, and you should have made a note of it, by default it is never shown in plain text.
Luzern
Fixes: 9
@RealAleMadrid   I referred to the warning about cookie settings in my browser
Luzern
Fixes: 9
@jab1 Mytime with Plunet is long back to steam, and i've changed words several times. Event has not occured before.
Tried EDGE and got in with the dets ils used my usual browser. s Works on Chrome now. Bemused.
Fixes: 387
Glad you've solved it, @Luzern . Out of curiosity, what is you 'usual' browser?
RealAleMadrid
Fixes: 68
@Luzern You haven't answered my question, it is entirely up to you, but if you wish to do so what do you mean by  "making dsl.plus.net permanent"  How is it relevant to cookies? As far as I know dsl.plus.net is an incorrect corruption of plusdsl.net which is used in the router username field.
Luzern
Fixes: 9
@RealAleMadrid  from earlier post
Throughout I have found  "
Well having checked Chrome settings to make sure 'allow' was selected,  I  chose a further option that adds permanently allowed sites
Sites that can always use cookies
If what I Put im reply wa incorrect it wad accidental
        i
Luzern
Fixes: 9
thamks all
