Major fibre broadband installation fail - plusnet
- Feedback
- Plusnet Feedback
- Re: Major fibre broadband installation fail - plus...
Re: Major fibre broadband installation fail - plusnet
01-08-2015 11:08 AM
Well - it would appear things have finally got there!
Thank you everyone for your support!
01-08-2015 2:18 PM
Quote 2.2.1 Dynamic Line Management
Dynamic Line Management (DLM) is employed in GEA-FTTC. DLM constantly manages lines to maintain a target link quality (speed and stability). It does this for as long as the product exists.
At provision, the line is put on “wide open” VDSL2 line profiles allowing the upstream and downstream line speeds to run at the upper limit of the product option selected.
On the first day of operation, DLM will intervene if severe instability is detected. Otherwise, DLM will wait until the day after provision before deciding if it must intervene, provided that the line has been trained up for at least 15 minutes during the preceding day.
BT SIN 498.
01-08-2015 2:55 PM
This is what my blurb currently says:
Phone exchange:
REIGATE
Estimated line speed:
69Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-06-23 13:46:31
Current line speed:
38.6 Mb
I left the support ticket open with a request staff just give things the once over. Hopefully they'll let me know if there is a problem, but it doesn't seem to want to use the full line (I know it won't really get near 69Mb!). I had hope 'training' would increase this speed but you're saying training's done? I can get the odd burst to 42MBs. Stability seems good.
Hmmm.
01-08-2015 3:03 PM
and what does the BT Speedtest say your IP profile is ?
01-08-2015 4:09 PM
Phone exchange:
REIGATE
Current line speed:
38.6 Mb
Download speedachieved during the test was - 37.29 Mbps
For your connection, the acceptable range of speedsis 20 Mbps-38.72 Mbps .
Additional Information:
IP Profile for your line is - 38.72 Mbps
What I bought from Plusnet:
HIS IS YOUR CURRENT BROADBAND PACKAGE
Unlimited Fibre Extra£19.99
per month
Unlimited Usage Allowance
70.5Mb download speed (estimated)
20Mb upload speed (estimated)
You've 17 months left of your 18 contract
Designed for demanding users
01-08-2015 4:11 PM
01-08-2015 4:14 PM
Thanks - I just updated that information for you!
01-08-2015 4:18 PM
I see you had posted the Line Speed, Must go to specsavers Although it's the BT IP Profile that really gives the game away that there's something wrong, it looks like you're on a 40Mb provision. I'm sure Chris will sort it out...
Quote What does https://portal.plus.net/m...ction=data_transfer_speed say now ?
01-08-2015 4:20 PM
I've just put a modify order through to fix this and it should complete on Monday.
Sorry about that!
01-08-2015 4:22 PM
Clive
01-08-2015 4:27 PM
01-08-2015 4:28 PM
02-08-2015 5:50 PM
Just some info. You posted the downstream IP Profile from the BT Performance Test Further Diagnostics page. This post is no use to you at this point in time, but may help anyone with a similar problem reading this thread.
The upstream IP Profile makes it obvious, because it bears no relation to the upstream sync. It is the limit of the package ordered. Always 2, 10 or 20 depending :).
02-08-2015 6:47 PM
As things are, it seems Plusnet accidentally put me on the half-way broadband fibre package instead of the full. Chris is rectifying it so by Monday pm I should have everything I ordered.
06-08-2015 11:53 AM
Many thanks to Plusnet staff for bringing this to a very happy and satisfactory closure. Matty, Chris and all - many thanks!
I am now running at full blast (I mean broadband is - ahem, not me personally) and all is well.
And thanks for your comments all - it's been an interesting experience.
I'll sign off here and and this thread is closed. Cheers all!
- Feedback
- Plusnet Feedback
