Showing results forย
Search instead forย
Did you mean:ย
MSO
rongtw
Fixes: 12
MSO
I awoke this morning to find I had no internet ๐Ÿ˜• so did normal things reset router, power off 10 mins , restart still nowt , checked log at 03.00 it lost connection ?
Nothing on PN service status , went to Chat agent was excellent after 30 mins of checks. He found out By had a MSO in my area .
Still nothing on PN ! But Zen web page says MSO 44028 . Huh
If PN had updated service status I would not have wasted a chat agents time ๐Ÿ˜•
5 REPLIES 5
chenks76
All Star
Fixes: 12
Re: MSO
surprised that it took the agent 30 minutes to work out there as an MSO.
surely that would be the first thing they would check.
rongtw
Fixes: 12
Re: MSO
No Chenks ! He did exactly what I did first , check basic error first ! Reset router etc ,, then after it still not working check further , then he found MSO .
Simple fault check first
chenks76
All Star
Fixes: 12
Re: MSO
shouldn't take 30 minutes to do a simply fault check though.
if the agent had checked for an MSO then they would have saved 30 minutes.
no point doing a fault check if they know there is an MSO.
rongtw
Fixes: 12
Re: MSO
Yes but still no updates on PN service status page , ๐Ÿ˜ฏ
rongtw
Fixes: 12
Re: MSO
Update Smiley  i have my conection back now
