Long term sync speed problem
- Feedback
- Plusnet Feedback
- Long term sync speed problem
- « Previous
- Next »
Re: Long term sync speed problem
01-09-2009 3:30 PM
Both routers connect at approximately the same speed though.
Anyway we have made an appointment for Openreach/BT to visit tomorrow to look at the problem.
02-09-2009 2:00 PM
Apparently he is only supposed to spend 2 hours looking for a fault and is only allowed to swap connections over once if the test indicates no fault.
He mentioned a reference test (which gave 3.2M). Does anyone know what this means? He also managed to sync at 3.5M in the next road, about 200m away. He also said that the RAMBO may reset after a day and give me better speeds. Does this refer to the target SNR margin? If so, I doubt it will reset in a day. It's been at 15dB since I have been monitoring starting in April.
02-09-2009 2:31 PM
I strongly suspect that he is referring to a combination of your line profile and the target SNR on your line.
I'd suggest monitoring it and rebooting your router first thing tomorrow morning when the line is likely to be quietest.
02-09-2009 3:35 PM
Another rant: I've just seen the update on my ticket suggesting that the problem is solved due to a rise of 32Kbps in sync speed. Sorry but there's smoke coming out of my ears right now
Yet another rant: Why can't the engineer stay long enough to fully investigate the problem? It's very inconvenient to have to keep taking time off work for appointments.
03-09-2009 8:18 AM
03-09-2009 9:00 AM
Sorry the engineer visit didn't achieve anything
I've passed your fault back to BT.
03-09-2009 9:43 AM
Can anyone from PN comment on my point above ("Yet another rant")?
03-09-2009 9:47 AM
I'm not saying it's ideal, or particularly sensible, but the SFI charging model is based on 2 hour engineer slots.
It doesn't really sound like the engineer managed to achieve anything, other than replace a telephone socket in those two hours, so I'd be hopeful the next one is more productive.
03-09-2009 10:09 AM
BTW: The socket was replaced on the first Openreach visit (for a voice fault). The second openreach visit was for the broadband. He replaced a short length of cable at the pole and tested between the cabinet and my house but run out of time to do any more. If the fault lies elsewhere it could take several more visits to sort out. I don't have that much holiday from work
03-09-2009 10:13 AM
07-09-2009 5:47 PM
Now to wait for my IP profile to catch up
- « Previous
- Next »
