Lack of support from Plusnet
- Feedback
- Plusnet Feedback
- Re: Lack of support from Plusnet
06-03-2009 10:45 PM
I was expecting by now a rise in my IP Profile but nothing so far , do you want to see the rest of the graphs or shall I just keep them in case you need them later, Jack.
07-03-2009 2:47 AM
Anything with spikes like no:3 today (6/3/09), or especially 1925-2125 where there is a scaling change & 1623-1823 yesterday (5/3/09), or step changes such as 1039 & 1049 on the 4/3/09. With these latter two, if you can't spot the steps on DMT, they're a bit more obvious on RS if you look at graph RS1.jpg you posted, you'll see how the level suddenly steps below (in this case) the average. All these, and any you are just not sure about, post them.
Profile - what was it when you posted earlier? Run a BT speedtest Saturday mid/late morning if you can and see what the member centre is saying as well. If you are around Saturday to be able to do it post a DMT shot from a similar time slot say mid-morningi/lunchtime-ish.
07-03-2009 10:03 AM
I've been checking my Profile daily on BT and this morning it has increased, now just wait for Plusnet to catch up. I'll run DMT from around 11.00>13.00 as I'll be busy afterwards, as it runs itself I'll leave RS on all day, can always check the log if needed, Jack.
07-03-2009 12:54 PM
Here are the Graphs for 10.45>12.45 today, Jack.
07-03-2009 2:24 PM
Glad the profile's up.
07-03-2009 8:31 PM
07-03-2009 10:41 PM
The way to go is to start tweaking, you've got more control at the moment than you have over BT! If things end up perfectly stable with you setting the Target, and then things go pear-shaped if BT reset it, you will have a clear case to get BT to do something, otherwise all and sundry will just turn round and say your line is no longer stable with a 6dB target - not what you want.
Tomorrow daytime, if the SNRM is steadily showing 9dB +/- a few 10ths, then move the target slider to 80% and press the button, hopefully you'll sync above 6816 which will also put you into a 6M IP profile.
If the errors continue to look good for a while, then one could go for a bit more. I'm relucant to suggest going the whole hog in one go in case it goes tits-up and your target gets worse.
07-03-2009 10:57 PM
08-03-2009 2:23 PM
Results after following you suggestion, please note the DMT download I was using decided not to cooperate this morning so used a new download from Oldjims original message, they look OK to me, what do you think?, Jack.
08-03-2009 2:45 PM
08-03-2009 3:08 PM
08-03-2009 3:26 PM
Question - are you not too far away from a Marina by any chance?
08-03-2009 4:13 PM
08-03-2009 4:32 PM
08-03-2009 5:03 PM
About a year ago we had problems with interference on television and had a Investigator from OFCOM and he spent a lt of time checking out the vicinity without finding anything, eventually he said it was someone with an aquarium and the heater was causing the problem, he then left us to check out our neighbours for fish tanke. Two days later an immersion heater on the same floor as me packed up, after it was replaced no more interference!!
We have very local (about 150 m. a radio transmitter and a taxi office with a transmitter but both of there he checked and declared them clean, I can't think of anything else in the vicinity, there are a couple of car repair shops but if they were using any welding equipment it would only be in working hours which would rule them out I think, Jack.
