LRS
Oldjim
Resting Legend
Fixes: 63
Re: LRS
Tools
Options
Privacy
chandu
Re: LRS
Oldjim
Thanks for the help, but still can't find the cookie bit.  Something is not right here.
Oldjim
Resting Legend
Fixes: 63
Re: LRS
This is what you should see - You can see if you have blocked cookies for Portal.plus.net by looking at exceptions
chandu
Re: LRS
Quote from: Oldjim
Thank you Oldjim. Now I can access the portal in FF.  But I keep getting repeated "allow/deny/allow this session" box.  Any ideas?
Oldjim
Resting Legend
Fixes: 63
Re: LRS
Is there an option in the popup to tick for always allow
chandu
Re: LRS
@Oldjim
Yes, there is in options -->Contents Tab --> Block Pop-Up Windows is ticked.
Oldjim
Resting Legend
Fixes: 63
Re: LRS
Mine isn't but I have no idea why that is classed as a popup
chandu
Re: LRS
Oldjim,
It worked yesterday and today it giving me the same old page not found error despite my setting the portal.plus.net to allow as suggested yesterday.  So, there is something on FF I am missing.
adamwalker
Fixes: 223
Re: LRS
I'm not sure what else you could try Chandu, maybe remove and re-add your pop-up blocker?
I'd not dwell on it too much if it's just an issue with the one page which works OK in another browser.
 Adam Walker
chandu
Re: LRS
Thanks Adam.  I have now given up on that page, though it does worry me for it not to load.
chandu
Re: LRS
@Oldjim & Adam Walker
Thanks for your help.  The issue appears to have been sorted using AdwCleaner, which I had heard of through PN Forum.  A great programme.  Grin
MattyC
Fixes: 46
Re: LRS
Glad to hear that this got sorted in the end Smiley
Matty
