Itemised phone billing
- Feedback
- Plusnet Feedback
- Re: Itemised phone billing
31-08-2011 6:34 PM
This is just a idea
Today I needed to get a phone number from my itemised phone billing... I did find it how ever it took me almost 10 minutes
any way the question I have is this
would Plus Net implement a search bar so we can search let say the area code?
as Im possibly not the only person to search for phone numbers
8 REPLIES 8
31-08-2011 6:45 PM
very easy to get, at the bottom of theitimised bill page you looked at it says
TOTAL: 10 01:35:00 £0.00 View details
Download a copy of your call information for this month (in CSV format)
put this into a spead sheet and you can sort it on the number column
31-08-2011 6:56 PM
i know a few ways we can do it
but as im also a computer geek so to speak... i know it wouldn't take much for plusnet to implement such a item and im sure it would help out other people
31-08-2011 6:58 PM
you dont need anything new it is there already
31-08-2011 7:05 PM
but if you'r in a rush you wouldn't really want to be messing around
it was just a idea i thought i might put to P/N and see what they think
31-08-2011 7:15 PM
From https://portal.plus.net/my.html?action=mydetails&?membermenu=accountdetails
Select Phone Calls from the top menu
Then View
Then Itemised Bill - See first picture for the result
You can change the dates to suit
Then you can click on View details
It took me less than one minute after the website loaded slowly as usual - of course we don't make many phone calls and I knew which month to check
Then View
31-08-2011 8:10 PM
im all-ways on the phone
at the moment any-ways
and whats with the website loading so slow? it all-ways loads slow for me and im on a 8 meg line :s every other site is fine
01-09-2011 2:45 PM
01-09-2011 4:01 PM
cheers Adam
as i said only a idea but thats what this forums for
