It's Gorn!!
- Feedback
- Plusnet Feedback
- It's Gorn!!
It's Gorn!!
16-10-2008 2:15 PM
Currently on the right hand side of the initial Member Centre page is a poll about why people have come to the Member Centre today. At the moment the option with the highest votes at a steaming great 74% is "view my usage".
So why has the view my usage link disappeared and been replaced by a Upgrade Account link, eh?
OK, it's easy enough to add a bookmark to the right place (once you've found it) but deleting it from the initial page ain't exactly user friendly
Rant over; normal service can now be resumed
Re: It's Gorn!!
16-10-2008 3:11 PM
Re: It's Gorn!!
16-10-2008 3:23 PM
Re: It's Gorn!!
17-10-2008 11:44 AM
Re: It's Gorn!!
18-10-2008 8:10 AM
I'm going to issue a challenge to Peter Jackson. Let's see how long it takes you to take this by the scruff of the neck, mail whoever gives permission for this change, obtain that permission and set someone the task of swapping in or adding the VMBU link to the front page.
To save you time, don't bother with explanations of how the system works or any progress reports, just see how efficiently you can action something as simple as making a link that would benefit a vast majority of plusnet customers.
Your time starts .... on 16/10/2008, 15:23
Re: It's Gorn!!
18-10-2008 8:57 AM
Have I misunderstood something here?
Re: It's Gorn!!
18-10-2008 11:47 AM
Re: It's Gorn!!
20-10-2008 9:17 PM
It took me 10 minutes to stumble upon a link to its new location. And how long does it take to fix?
Re: It's Gorn!!
23-10-2008 2:02 PM
If so, I reckon I can get this added back. See screen shot for confirmation of where you are talking about.
Ex-Plusnet Jobsbody
Re: It's Gorn!!
23-10-2008 2:11 PM
Re: It's Gorn!!
23-10-2008 2:12 PM
No, thats not it!
Once you have logged into the Member Centre, alongside the green-bordered panel for Help and Support, there is a maroon bordered panel for My Account. When you first sign up to PN, in place of the Upgrade in this panel there used to be a link for View My Usage. This seems to get replaced after a couple of months by the Upgrade Account link. I noticed this not only after I signed up but also the same happened for a referral account.
I hope this is clear, I haven't worked out how to capture the screen image and post it on here!!
Re: It's Gorn!!
23-10-2008 2:16 PM
Re: It's Gorn!!
23-10-2008 2:19 PM
Quote from: Kelly So let me get this right. We used to have a link on the secondary nav bar to view my usage, and that is now gone? (replaced by upgrade)
Not quite. See image below (I hope) for where it used to exist......
Perhaps it would be better in a more prominent place on a menu - eg My Account
Re: It's Gorn!!
23-10-2008 2:24 PM
Quote from: Jameseh Press the Print Screen button on your keyboard. Then you can go to MS Paint and paste that image into there and save it
Print Scrn key seems to be disabled on this system at work - either that or there are so many biscuit crumbs underneath it won't work. If I have to work late and the cafeteria is closed at least I can try to shake them all out if I get a bit peckish.
MrC at least has managed to produce what I was trying to explain.
Re: It's Gorn!!
23-10-2008 2:57 PM
However the poll suggests restoring VMBU as a permanent feature of the My Account box would be well received.
