Is there a problem with Auto Login?
NedLudd
Each time I access things like 'Line Rental Saver' and 'View your broadband usage' I am asked to login.
So, having done that, I go to 'Auto Login' and set it up for 1 year. The system then confirms that it has done that.
But, the next time I try to access the above I am asked to login!!!
Is there a problem?
Geoff,
York.
6 REPLIES 6
Oldjim
Resting Legend
Fixes: 63
Re: Is there a problem with Auto Login?
Line rental saver always does that but not View my usage
It is controlled by cookies - have you set your browser to remove them when closing
NedLudd
Just checked 'Auto Login' and it's lost the setting in the same browser session!!!
Checking the cookie settings right now Jim!
Geoff,
York.
Oldjim
Resting Legend
Fixes: 63
if you can't see anything wrong I suggest deleting the Plusnet cookies and starting again
Mav
Fixes: 518
I seem to remember this coming up before and the suggested setting was 2 years which has always worked for me.
I have noticed, though, that if I've logged in on another PC/device the setting appears to get turned off.
Forum Moderator and Customer
NedLudd
Just tried 2 years Mav and that appears to have stayed on the system!
Thanks!  Wink
Geoff,
York.
Mav
Fixes: 518
Glad it seems to have worked Smiley
