Is something wrong with usage recording?
Surfer
Re: Is something wrong with usage recording?
Something wrong here!  On checking a breakdown of my usage 2% was recorded as gaming.  I have never done any gaming online in my life and never will as I haven't a clue how it would be done!  I can understand streaming from watching Youtube clips.  Something weird is going on with usage figures!
spraxyt
Resting Legend
Fixes: 75
A small amount of misclassified traffic is normal and doesn't mean anything is wrong. The Ellacoya traffic classification devices have no knowledge of what you are actually doing, just make a best guess as packets fly past.
David
Surfer
Kb is acceptable, but megabytes is not.  I did a check on my line via the Kitz website and under the RAG test it showed the following;
Check: The check identified another service on your line which may prevent you from ordering a new ADSL connection. Examples are : Existing adsl connection, DACs, LLU, TPON etc came
Not sure what the above means.  Surely it should show no compatibility issues?
jelv
Fixes: 10
It means you have a broadband connection on your line!
That test is only of use for testing a line before BB is installed.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Surfer
Thanks.  I thought as much, but was not sure.
