Internet outage again...
- Feedback
- Plusnet Feedback
- Internet outage again...
04-11-2011 11:53 PM
Several times in the past few months, I've ended up losing the internet connection for my house
all the lights on the router are on, except for the internet light.
The first time it happened about a month ago I tried using a different router, because when I rang support I was told it was likely that my router was faulty... it worked for a while as the internet eventually came back on by itself after about 12 hours.
It went out briefly not long after this but came back on by itself again - but this time it's gone off and it's not coming back on at all, despite having rang the support line and gone through all the steps to reset the router
It's been about 24 hours now and still nothing...
Has anyone else experienced this? It seems like I'm having a lot of bad luck at the moment! >.<
6 REPLIES 6
Re: Internet outage again...
06-11-2011 4:11 PM
in a word, yes, you are not alone.
07-11-2011 9:31 AM
@Rose90 - I can see you're still not able to get online, and that your fault is with our faults team - thanks for that. We'll get that tested and updated as soon as we can, sorry for the delay.
@twitchy14 - From your connection logs it looks like you might have a dropping connection fault, if you could run through the checks at http://faults.plus.net we'll be able to check on things for you and get it sorted.
07-11-2011 5:36 PM
I ma having the same sort of issues, as soon as I phone plusnet though internet comes back. I am note sure but I think the problems started when I moved packages.
07-11-2011 10:02 PM
Moving packages makes no difference, its coincidental.
@thecount it sounds like you should go through the faults checker too, following the steps can rule out any internal problems OR get on to PN to get BT to come take a look
Regards
Regards
07-11-2011 10:36 PM
I have been through the fault checker, my router is has been in the Main socket and has stayed stable for 12 hours however I have moved it back to another socket and it has stayed stable for 3.5 days. I think all these probelms have started since I moved to ADSL 2, I would prefer to go back to ADSL as Imy internet was never disconnected. You hvae offered to provide me with a router however I only have a seven day return policy and it it goes wrong after 8 days I don not want to get stuck with a router I dont need.
07-11-2011 10:42 PM
The plusnet supplied router is.... meh.
You'd be better getting one from elsewhere if thats the case..
How long do you want it to stay synced? Your not gonna get amazing uptime from an ADSL connection, its bound to resync and reconnect, its the nature of the beast
Regards
Regards
