How to do it?
Roberto0151
How to do it?
Having had a problem, raised a question and got a perfectly satisfactory result,  I went to close the question in order to avoid any unnecessary further correspondence but could not find any obvious means of doing so.
I expect I'm being (un)usually dumb, but have I missed any obvious button to click?
6 REPLIES 6
shalom2010
Re: How to do it?
I would just add a comment that the issue is now resolved!
Roberto0151
Re: How to do it?
Yep, I take the point, but that still gives the poor devils on the help desk something extra to deal with.    Smiley
Oldjim
Resting Legend
Fixes: 63
Re: How to do it?
If you raised the question you should be able to close it but if it was raised by a staff member after you phoned in then you can't close it
Roberto0151
Re: How to do it?
Thanks Oldjim, that makes a lot of sense.
Anotherone
Champion
Fixes: 21
Re: How to do it?
It'll close by itself after 14 days, but if it gets in the way of opening any others (IIRC the limit is 3) then post the ticket number and ask for a DCT member to close it.
orbrey
Re: How to do it?
Hi Roberto0151,
Thanks for letting us know, and glad it's sorted - I've closed the ticket for you Smiley
