How long to get a problem fixed
- Feedback
- Plusnet Feedback
- How long to get a problem fixed
Re: How long to get a problem fixed
14-12-2009 5:52 PM
I can't see how i'm going to get time of between now and Jan
15-12-2009 10:02 AM
I've just tried to give you a call, unfortunately it appears you were unavailable so I've left a voicemail.
The next step is an engineer appointment as you've eliminated your internal wiring as the caused of the problem. I've left you some information by VM so if you can let us know when is good for you we'll get it booked.
15-12-2009 5:00 PM
Thanks for trying but when i said no time off i meant no time off no Sats or Sundays until xmas
Thanks again
15-12-2009 5:07 PM
If you can let us know as soon as you know your availability we can get an appointment booked early in the new year.
16-12-2009 5:56 PM
The socket you can see is the BT master socket
The router you can see is brand new with the latest firmware installed its a netgear DG834G with firmware version V5.01.14
The cable and microfilter are brand new
As you can see there are no extensions,no sky,no phone, zip nada nothing zilch
I have a tower unit and laptop, running different AVG i can connect both wireless and via ethernet it makes no difference.
So I can't see what I've got connected incorrectly
Anybody still think my equipment is faultty
16-12-2009 9:06 PM
ps did you take that picture when you first set up your connection, the timestamp is quite old
16-12-2009 9:59 PM
28-12-2009 8:25 PM
Last three entries on my ticket read as follows
11:41am, Monday 21st December 2009
Thanks for getting in touch, please let us know when you are going to be available for a engineer visit as soon as you know, and then we can arrange this for you for the problems to be investigated.
Kind regards,
Your comment 12:44pm, Thursday 24th December 2009
Can you book an Engineerr to visit
Im available from 11-01-10 to 15-01-10
Please can you comfirm when you have booked the engineer for
regds
Monday 28th December 2009
The broadband fault has been closed by the supplier. Should problems re-occur, please restart the Broadband Fault Checker.
_______________________________________________________________________________________________
Thats got to be a joke im now expected to go through all the hoops again well forget it
A joke is a joke but this is now taking the piss
29-12-2009 11:07 AM
The support via the ticket system has been the worst customer service i have ever experienced from both the point of both a supplier and user
thanks to thosre on here who tried to help
29-12-2009 12:51 PM
That message just means BT closed the fault (possibly due to engineer appt times). You wouldn't need to go through the whole testing process again, we just need to reraise to BT.
29-12-2009 2:02 PM
____________________________________________________________________________________________________
Now i know my English ain't that good but that statement reads.BT has closed the fault,if the problem re occurs restart broadband checker
If it is supposed to read ANYTING else then it should read exactly as it should
As ive said ive had enough of running through hoops for PN, i dont care what problems they have with their supplier they are not mine.
30-12-2009 3:21 PM
Not had any dropouts since,
30-12-2009 5:21 PM
01-01-2010 1:48 PM
Today i disconnected the bell wire at the rear of the BT master socket
my router jumped up to a DownStream Connection Speed of 3168 kbps
My download speed is still only 1mb max,but i know the problem is not on my equipment
01-01-2010 3:47 PM
