High Speed Broadband link disappeared from Connection Settings
- Feedback
- Plusnet Feedback
- High Speed Broadband link disappeared from Connect...
Re: High Speed Broadband link disappeared from Connection Settings
02-08-2015 8:50 PM
02-08-2015 10:26 PM
A Current line speed of 77.2Mbps sugges.ts your BT Wholesale IP Profile is 77.4Mbps, which in turn suggests a sync speed of the full 80Mbps. (Often 79,999kbps).
The CLS is expected to be 0.2Mbps below the IP Profile but conditions can arise for short periods where there is a big difference either way. Whichever is the lower governs your maximum speed.
Why your white-box is only showing 64.41Mbps average is another question. Is it low from 6pm to midnight/1am? And well over 70Mbps through the day? If so you are probably experiencing the same speed problems as several of us.
03-08-2015 10:47 AM
Update: Details are attached
days worth of readings for you all 🙂
06-08-2015 2:44 PM
Quote from: Chris Hi all,
I don't think this icon will be reappearing. The information on there, whilst useful for some people shouldn't really need to be shown as the profile should (and it does update the vast majority of the time now) keep up to date with the IP profile which is the more relevant number when looking in to connection problems.
So please could you explain why there have been a couple of posts today where it hasn't updated
28-08-2015 10:40 AM
The people who are most saddened by these actions are generally those who have been most helpful in giving us 'ordinary' users advice on how to solve problems and improve connections. Why would Plusnet want to alienate such helpful people? Or does Plusnet just take such people for granted? The recent example of the collapse of the Labour Party in Scotland might serve as a warning against taking supporters for granted...
28-08-2015 10:42 AM
29-08-2015 4:24 AM
And i have experienced the plusnet profile fail to auto update, once it failed to update following DLM mismanaging my connection, lowering the BTW IP profile and throughput , It has also done this more frequently in the opposite direction (usually after DLM increased the sync rate ) even after refreshing the PPPOE session several times , had to ring to get it manually set many times
If your IP profile is 77.2 then your circuit has G.inp enabled and your BTw IP profile will be 77.35 Your max throughput should be around 73.5mbps on Plusnet looking at the white box data in your ss, looks like possible peak time issues, try gateway hopping ,
29-08-2015 9:04 AM
I would certainly like to see an explanation for why there are still so many not updating. I'm sure Plusnet are well aware of the reasons as there have been thorough investigations in the past. I suspect it's an issue to do with their "suppliers" but of course Plusnet don't like to admit that BTw are one of their "suppliers" or that they might possibly be responsible due to a lack of timely delta reports.
10-09-2015 8:11 PM
So the removal of the this info on PN's secondry IP profile Should be shown in the Portal It's a cop out aimed at reducing support calls ect , and nothing more
Basically yet another reason to avoid plusnet if one was needed
10-09-2015 8:19 PM
10-09-2015 8:31 PM
https://www.plus.net/my.html?action=data_transfer_speed
To be is to do - Kant
do be do be do - Sinatra
10-09-2015 11:43 PM
12-09-2015 6:48 PM
Has anyone else tried calling CS
, if they get a flood of phone calls then maybe it could be sorted
12-09-2015 9:13 PM
05-02-2016 11:36 AM
- Feedback
- Plusnet Feedback
