Help Assistant removed - unable to view tickets
- Feedback
- Plusnet Feedback
- Help Assistant removed - unable to view tickets
24-03-2015 7:42 AM
Re: Tickets
24-03-2015 8:00 AM
See http://web.archive.org/web/20141129084142/http://portal.plus.net/wizard/?helpheader=helpassistant
Re: Tickets
24-03-2015 8:00 AM
Re: Tickets
24-03-2015 8:07 AM
@kevinduke Can I suggest you edit the first post to change the title to something like "Help Assistant removed - unable to view tickets"
Re: Tickets
24-03-2015 8:13 AM
BTW: The quick way to get to view tickets is: http://contactus.plus.net/
Re: Help Assistant removed - unable to view tickets
24-03-2015 8:14 AM
24-03-2015 9:59 AM
Yes, the link has been moved for the help assistant and yes, this was deliberate.
Since we introduced the online chat functionality we've found that the satisfaction rating and speed of response on this is vastly superior to the ticket system, so we're promoting this more. If you have a query that you'd like addressing online rather than calling, the live chat team will be able togive the same response you'd get from a ticket. The team are the same people that reply to tickets but chat is proving more efficient with a higher satisfaction rating.
We're continuing to review the ways customers contact us and may make changes/updates to this again in the future.
If you have an open ticket at the moment, you should receive an email when we reply to it which tells you where to go to view it and respond.
There is also a link still to the help assistant and therefore to view your open tickets towards the bottom of the page once you've logged in at the member centre.
If you've got an issue you want to raise by ticket, why not give the live chat a go?
24-03-2015 10:22 AM
which takes me to a page with the heading
Help & Support
Find the help you need or ask a question
So how do I ask a question from that page - and saying Ask Jess is completely unacceptable
24-03-2015 10:28 AM
Submitting tickets is ideal for non-urgent requests or those that require more detail to be sent up front. Online chat is informal and not time efficient from a customers point of view.
There's also the issue that the page design of http://www.plus.net/help/?home=helptop doesn't draw prominent attention to the chat facility (in my view)...
24-03-2015 10:31 AM
https://www.plus.net/home-broadband/contact/
24-03-2015 10:35 AM
b) Chat is currently 'offline'...
24-03-2015 10:43 AM
As I am a customer
Click on Contact Customer Services
The only options are phone or on-line chat NOT Raise a Ticket
Visit Help and Support is equally useless
SO IS THIS A DELIBERATE ATTEMPT TO STOP CUSTOMERS RAISING TICKETS
Apologies for shouting but in my opinion this decision is totally ridiculous
24-03-2015 10:45 AM
We were always told that we had to use tickets and that email was NOT an acceptable method of communication because it wasn't fully traceable and audit-able.
Tickets aren't only used for reporting problems. You have made it harder to find any Service Notices or automated tickets. You are deliberately hiding this information from new users who probably don't even suspect that it exists hidden in the bowels of the help system.
24-03-2015 10:55 AM
All chats are logged and recorded, we can access the logs if needed and a customer can request the chat log is emailed to them as part of the chat.
I'm flagging all of this info back in internally so we can see the different points, opinions and comments here.
24-03-2015 11:04 AM
Either
I want to raise a ticket to which I can add screen caps and a file
I want to view my closed tickets or indeed open ones
Also
A poster on here says - I didn't receive an email about something - so what do we recommend - View your closed tickets not use live chat or phone in
- Feedback
- Plusnet Feedback
