G.Fast will available soon?
Fixes: 117
Re: G.Fast will available soon?
@jab1
Here's some detail on the copper VOIP
https://www.theregister.com/2020/03/03/openreach_ip_voice_network/
The plan appears to be to switch off the PSTN (ie voice) network leaving the copper in place for internet.
Fixes: 385
Yep, think that is where I read it myself @bmc , but it seems to have stalled and gone very quiet, although it is still referenced on the BT Availability checker.
Fixes: 117
@jab1
I suspect it'll only really come into play when they start trying to close down the PSTN part of an Exchange. Any customer not on the Internet will be given a SOGEA phone connection (whether they like it or not!).
Fixes: 117
@jab1
Speaking of closing down the PSTN part of an Exchange have a look at
https://www.ispreview.co.uk/index.php/2021/05/openreach-stops-selling-traditional-copper-phone-in-mi...
pint
Plusnetg and other ISPs offer a home move option, what f you are moving to one of these stop sell locations?Huh
 or change ISP in one of these areas? IE Sky/Talk talk or other  LLU to openreach, or VM to openreah
The advice on the openreach states that in the event of a powercut  is this
" Most people in the UK have a mobile phone, so the advice is just as you do today, use this as a backup in case there is a power cut."
But yet if you are in an area with a weather warning, this will advise that the area may expect powercuts due to the weather, and a loss of mobile phone reception due to the powercuts ( knocking out the base stations)
goldenfibre
Seasoned Pro
Fixes: 12
I just left Plusnet.
Got new G.fast 160/30 today. 😁
https://www.thinkbroadband.com/speedtest/1621957043554724355
goldenfibre
Seasoned Pro
Fixes: 12
Following up from yesterday (good job I order 160/30) as impossible to get 330/50 no chance!
xDSL Training Status: Showtime
Mode: G.fast Annex A
Traffic Type: PTM Mode
Link Uptime: 0 day: 0 hour: 4 minutes
xDSL Port Details Upstream Downstream
Line Rate: 29.023 Mbps 160.269 Mbps
Actual Net Data Rate: 28.881 Mbps 159.909 Mbps
Trellis Coding: ON ON
SNR Margin: 2.8 dB 4.8 dB
Actual Delay: 0 ms 0 ms
Transmit Power: 4.1 dBm 0.0 dBm
Receive Power: 4.7 dBm 3.0 dBm
Actual INP: 540.0 symbols 550.0 symbols
Attainable Net Data Rate: 28.571 Mbps 184.549 Mbps
