Feedback Tab.
gleneagles
Aspiring Legend
Fixes: 17
Feedback Tab.
A feedback tab has appeared on my tablet, forum page, and is positioned at the side of the page often blocking the red reply post tab....
How do I get rid of this thing, completing the feedback does not get rid of it.
Only appeared a few days ago but quite annoying....
Using a iPad.
We are born into history and history is born into us.
18 REPLIES 18
Mook
Seasoned Champion
Fixes: 9
Re: Feedback Tab.
Are you able to take a screen capture of this for posting please @gleneagles.
On your iPad press the top and Volume up buttons to capture the screen.
agedgopher
All Star
Fixes: 15
Re: Feedback Tab.
The feedback tab is also present on my PC.
Clicking it takes you to another survey page.
RobPN
Fixes: 15
Re: Feedback Tab.
Yep, I noticed it had appeared a few days ago.  Moderately annoying.
When I first noticed it I thought it was some sort of label telling me I was reading the 'Feedback' section of the forum and went elsewhere expecting it might change to something else, but no.
I also tried clicking it but didn't fill in the feedback form, and like @gleneagles found that I seem to be stuck with it.
Screenshot below @Mook
RobPN
Fixes: 15
Re: Feedback Tab.
@Mook
Screenshot above removed in favour of the one below, more relevant to @gleneagles problem of the 'Feedback' tab clashing with the 'Reply' button.
Mook
Seasoned Champion
Fixes: 9
Re: Feedback Tab.
Mmm, that's something I don't see on Safari OSX Big Sur, but I only have essential cookies enabled it may or may not have something to do with that. Or maybe its waiting its turn.
gleneagles
Aspiring Legend
Fixes: 17
Re: Feedback Tab.
May sound odd but it’s worse than the screen shot shown....that screen shot shows a slight gap between the red post tab and the feedback tab but when the iPad is in vertical position it obscures the red post tab, sure I can scroll to shift it but it a b nuisance, the other solution is to use the tablet in horizontal mode which does give a good gap but the point is why should I have to be dealing with this issue anyway ?
Is there any way to block this thing ?
RobPN
Fixes: 15
Re: Feedback Tab.
Well I've just managed to block the text from the button using AdBlock so now I'm just seeing a blank rectangle.
I'm off to do something else (i.e. have a late breakfast) but might have a look at finishing the job a bit later.
RobPN
Fixes: 15
Re: Feedback Tab.
I suspect that's down to screen resolution @gleneagles  Smiley
Mook
Seasoned Champion
Fixes: 9
Re: Feedback Tab.
I've just logged in on my iPad and I too see this Tab as you can see from the screen capture. However for me it's not in the way of any buttons regardless of orientation, so it maybe as @RobPN suggest @gleneagles down to your resolution.
Screen capture taken using top and home buttons.
Fixes: 388
Re: Feedback Tab.
Interesting - I don't see that on my laptop, but I use Firefox and uBlock Origin, which i suspect treats it as what it is - irritating carp.
Will have a look on the iPad once it has finished charging, but I suspect it will appear on there as I don't have any extra blocking program, other than the FF rules being as tight as I can make them without upsetting my browsing experience.
EDIT - as I thought, that annoyance pops up on the iPad, but doesn't obscure anything - 9.7" tablet at default settings.
198kHz
Fixes: 42
Re: Feedback Tab.
Irritating American carp !  😒
So who does see it?
BT technician (Retired)
Fixes: 388
Re: Feedback Tab.
@198kHz  No idea, but they won't be getting any from me.🤣
EDIT: Your link explains it all - typical 'social  media' wastes of space.
gleneagles
Aspiring Legend
Fixes: 17
Re: Feedback Tab.
So who does see it?
No problem giving them my thoughts.....
Likely to result in a ban for life from the forum.
Fixes: 388
Re: Feedback Tab.
You could just go for swim, @gleneagles 🤣
