Fed up with it now
- Feedback
- Plusnet Feedback
- Fed up with it now
Fed up with it now
30-06-2011 8:56 PM
Raising help ticket(s) in my case seems to have caused confusion within PN as i keep getting the same request/question over and over - Which if someone had read the tickets in full or asked me questions to help clarify my issue i think we would be nearer a solution. However no one from PN has called me once - i have called them 4 times now The last time today @ 12:30. No one has yet to answer my query of "am i being throttled" not that i download massive files - 80% of my online time is gaming which hardly uses any bandwidth up. I was told today my contention ratio is 50 :1 - is that right for a Pro package? My VP is ok apparently.
Is any]ne else on an old "pro" package that is getting useless gaming latency in the evenings? Am based in Market Weighton , East yorks. I may aswell play COD from the moon on an evening. speed test run just now....
Re: Fed up with it now
30-06-2011 9:03 PM
30-06-2011 9:13 PM
30-06-2011 11:36 PM
Hope you get it sorted soon.
Chris
01-07-2011 12:16 AM
If you download something across the midnight threshold does the download speed change at midnight?
01-07-2011 7:18 AM
firstly , you need if available to be on 21CN and have the upload uncapped.
this does make a fair bit of difference
secondly i found the thompson router 585 v8, poooh so i use a old BT HH2 seams a lot better for gaming.
next you need to go into router setup , and disable Upnp, unbelievable but yes it makes a difference .
and now i game fairly good connection with the odd ping spike on the evening but its a vast improvement since i first moved to PN
i am in west Yorkshire , with extra package only , i did try pro add on but made no difference to gaming
01-07-2011 7:24 AM
Things tend to return to normal before midnight.
Just seen rongtw added...
Thanks for the pointers im sure unless PN can sort this i'll have to look at that, But i have used this connection for 2 years without any problems, I want to know what has changed?
01-07-2011 10:19 AM
Are you seeing the same slow speeds on a BT speed test, and do you get the same high pings when gaming? Most important thing is to try the BT speed test when the issue is apparent though.
08-07-2011 9:43 PM
BT speed test run just before this gave 4.7mps...
I have an Engineer coming on Mondaty for a BOOST visit....to check for cable corrosion
I have asked countless times if I am being throttled....still no answer regarding this
Its an absolute joke the service i get in a evening
09-07-2011 7:48 PM
Certainly your upstream speeds are a bit better than on the other thread, but they still seem low. And the ping times are horrendous - but could be explained if packets require a lot of retries to get over a bad uplink.
Can you monitor and post a variety of the sync speeds, rather than (or in addition to) speedtest results? It would be good to get an idea of what theat is syncing at, and whether it is changing (ie disconnecting).
Quote Funny how the cable corrosion only affects me in the evenings....
Interference has this horrible habit of only turning up in the evening. My parents suffered a problem that only started at around 5pm, and went on until 9 or 10pm. That was mainly because of interference caused by internal wiring.
As I said on the other thread, though, interference on upstream is comparitively rare.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
11-07-2011 5:29 PM
Therefore at square one again. PN confirm i am not being deliberately throttled.
will mention upstream sync to PN in my ticket
12-07-2011 11:43 AM
I can see the usertools exchange checker is reporting the VP status as green but that's from June, so I've emailed to find out the latest on the exchange and will let you know as soon as we have any information back.
16-07-2011 11:38 AM
16-07-2011 8:06 PM
In fact, at present the manchester server is given extreme erratic results.
If you are going to use those services, you need to be completing at least 3 tests from different servers / locations.
My brother tried manchester last night and got 87 ping, 7 jitter, very poor line.
Immediately tried Maidenhead and got 31 ping, 0 jitter and grade A line.
So don't rely on those tests, you need multiple tests.
Also some tests may not work properly if your router is blocking ping from wan (internet side), such tests are found on dslreports website for example.
16-07-2011 8:23 PM
