FTTC Excellent but starting to slow
- Feedback
- Plusnet Feedback
- FTTC Excellent but starting to slow
12-08-2014 9:45 AM
Maybe the exchange thinks we have a fault so it has dropped our speed from 20Mbps to 15Mbps. The router and cables are sorted out now so if we could have a reset back to 20Mbps that would be great
BT IP Profile for your line is - 17.33 Mbps
Re: FTTC Excellent but starting to slow
12-08-2014 2:05 PM
High Low High Low
FTTC Range A (Clean) 29.1 20.4 6.5 4.6 -- Available
FTTC Range B (Impacted) 23.2 11.4 5.6 2.5 -- Available
12-08-2014 3:33 PM
12-08-2014 4:24 PM
I've taken a look over your line and there's nothing currently stopping it from receiving higher speeds in terms of your profile.
The highest your line has synced at is 20.2Mb/s, it has dropped slightly lower which may pick up again the next time you have a resync,
12-08-2014 5:07 PM
I'd leave it for a few days and then when things are quiet weatherwise - no lightning - I'd login to the router and Disconnect the PPP session, then power it down and then power down the modem and leave it all off overnight. Power up the modem in the morning, wait for it to sync up and all the lights go steady, then power up the router, login into it and Connect your PPP session. Then run the BTw test to see what the Profile is which hopefully might be better (and not worse!)
The Download speed may not improve immediately until your Current Line speed (Login required) catches up - again on the assumption it improves
14-08-2014 9:57 AM
I was hoping to get around 20M, even www.dslchecker.bt.com says i should be getting better then 16M download.
IP Profile for your line is - 17.06 Mbps
14-08-2014 10:10 AM
Try the overnight power off as mentioned in my reply #4 to see if you get any improvement.
What exchange are you on?
14-08-2014 10:27 AM
I am on the below exchange, it was only upgraded to fibre a few weeks back, the BT engineer said i was the 2nd person to get FTTC from that exchange.
http://www.samknows.com/broadband/exchange/NESHL
14-08-2014 11:13 AM
15-08-2014 9:05 AM
Tried it another 3 times and still get the same result, i will try again later but it looks like i slowed down even more. If i slow down much more i may as well go back to ADSL2+.
1. Best Effort Test:
Download Speed : 15.47 Mbps
2. Upstream Test:
Upload Speed : 3.81 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
15-08-2014 10:06 AM
Can you run the TBB checker http://www.thinkbroadband.com/speedtest.html
15-08-2014 10:10 AM
15-08-2014 10:18 AM
15-08-2014 10:24 AM
15-08-2014 10:30 AM
