Excellent work
- Feedback
- Plusnet Feedback
- Re: Excellent work
Excellent work
23-06-2010 6:41 AM
The client had been with AOL for years, had a crackly line since then, and suffered low sync rates, high error rates and frequent connection drops. A visit from BTO left him with no improvement, a suggestion that his wiring was poor, and a £200 bill. He then enlisted my help; after removing his extension wiring and doing the usual checks/improvements, the root problem remained - it was accompanied by a router-based warning that Uncancelled Echo was suspect (at a value of +23, whereas it is -15 on my own line). AOL would simply help no further, and BT said the line was OK (after remote test). I then persuaded him to switch tp Plusnet, where he received the usual, in my experience, excellent treatment. Plusnet tested, concurred the line/exchange was suspect, and arranged another BTO visit - the enginner arrived (Steve from York), did an excellent, professional job - remade connections in the village BT Cabinet, with the result that the phone line and DSL performance is now really good for our location....clear line, attenuation 55db, sync 3800kbps, SNRM 6, very low error rates, and a very happy client indeed.
Very well done, Plusnet - thanks.
Re: Excellent work
23-06-2010 10:43 AM
Thanks for your kind words and credit to the Open Reach engineer who dealt with that job in what sounds like an extremely professional and courteous manner. It means a lot to us to hear a happy story such as this.
Thanks again and here's hoping that everything continues to go smoothly for them and indeed for yourself.
Adam
Re: Excellent work
23-06-2010 11:01 AM
Cheers
B.
Re: Excellent work
23-06-2010 11:51 AM
As a matter of interest - does PN have to deal with BTW first in every case, who then bring in BTO, or is there a direct relationship between PN and BTO?
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Re: Excellent work
23-06-2010 11:52 AM
Re: Excellent work
23-06-2010 11:59 AM
Re: Excellent work
23-06-2010 1:06 PM
Our point of contact *is* with BT Wholesale, but if there is an issue that needs OpenReach interaction, the person at Wholesale will offer to put our call on hold whilst they speak to OpenReach. So whilst we don't speak directly with OpenReach, we will ask the relevant questions to Wholesale who then query on our behalf.
We do have escalation processes which we can follow to ensure that issues are picked up at a higher level with Wholesale, who will do the same at the OpenReach end.
Re: Excellent work
23-06-2010 1:20 PM
Re: Excellent work
23-06-2010 2:47 PM
Cheers
B.
Re: Excellent work
23-06-2010 9:13 PM
And yes, I hope that 'Steve from York' mentioned in the OP does get the recognition he deserves.
Re: Excellent work
24-06-2010 7:45 AM
Re: Excellent work
24-06-2010 9:51 AM
I hope it encourages him with his excellent work.
But without moving from AOL to Plusnet, my client wouldn't have had the help he did get.
