Easy product change process, but...
198kHz
Fixes: 42
Last night, with some trepidation, I went through the online process of changing product from Value to Extra on my 'other' account.
It was surprisingly smooth, quick and easy, so thanks for that.  Smiley
However, I find it surprising that there has been no email confirmation, and no record of the transaction to be found anywhere in the Member Centre.
Knowing PN as I do, I have every confidence that the change will happen seamlessly on my next billing date in two day's time, but I do think it odd that no record of the order appears to be available to the customer.  Huh
BT technician (Retired)
1 REPLY 1
orbrey
Re: Easy product change process, but...
I'm happy to say it has been scheduled, there's detail on service notice SN132568143 though I don't think that's emailed to you, I'll check on that.
Glad it went smoothly though Smiley
