Dangerous default re rDNS
Oldjim
Resting Legend
Fixes: 63
Re: Dangerous default re rDNS
One further point - until relatively recently customers had web space as standard - guess what - that was username.plus.com
So for anyone who used it their usename was in open view
Anotherone
Champion
Fixes: 21
Quote from: Chris
Plusnet have given their final written answer on this
Have we? I think a quick way of reducing some of the concern would be to get a message put on the Static IP addition page along the lines of 'If you choose a Static IP address, please be aware that the default rDNS (link to rDNS explanation) would be yourusername.plus.com - if you'd like this changing please raise a ticket to our support team'. Thoughts?
This thread has been flagged up internally, however please don't expect instant or even quick fixes to the actual DNS side of things (the text could be done pretty quickly) to this as I'm sure there is a load more backend stuff linked into the DNS system that I haven't thought of.
That's a very good starting place Chris, and in the first instance I think that's all most people would expect until chnages to the default settings are made which we appreciated would take a bit longer. I think your response is the sort of answer people were expecting some time ago.
Phileasfrog
Slap on the wrist for my "bump" accepted, but it does seem to have had the desired effect!  Cheesy
avatastic
Quote from: _Adam_Walker_
If we were able to provide options for rDNS or handle this differently how would people like to see that done?
>> Ticket is raised requesting static IP
<< Reply is given asking what flavour of reverse dns is desired, with options explained
>> Reply is sent with rDNS choice
<< Static IP and rDNS are applied at the same time.
It's not really rocket science is it?
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Bright
Setting up and paying for a static IP is currently an automated process though. Click the button, account charged, IP set up. Moving to a manual process probably wouldn't be attractive to PN, so using a different (anonymous) default rDNS setting would be better, with the manual process you suggest for those that want to depart from the default (once the default has been set up).
Anotherone
Champion
Fixes: 21
I see this has gone rather quiet! Has a Task ID been allocated to resolve these problems?
avatastic
It's on the TODO list right after Upgrade MySQL.
Fixes: 1,491
and wordpress
Fixes: 1,491
and the smf upgrade..
orbrey
It's with our web team as WDOP-169.
pwatson
WDOP?  Work Dropped On Pile?
orbrey
Web Development Operational.
Anotherone
Champion
Fixes: 21
Can Plusnet update us on this issue please?
orbrey
It's currently set to roll in the release we've got due on June 18th, I'll keep chasing it though.
jimbof
Thanks for bringing that to my attention Anotherone, I've put in a ticket to get mine changed! Smiley
