Customer Login page
ke1thd1an3
Customer Login page
On the Customer Login page, the login sequence requires 3 selections :- Username/Provider/Password as on my attachment.
Could you possibly move the 'Provider' option to either the start or the end of the selections, rather than in the middle?
That way I can use the 'Perform Auto-Type' option on my KeePass password manager, rather than having to copy and paste the Username and Password separately. KeePass can't Auto-Type with the Provider field in the middle of the sequence.
Pretty please?  Wink
5 REPLIES 5
Strat
Fixes: 565
Re: Customer Login page
Highly unlikely I would suggest Sad
rongtw
Fixes: 12
FF remembers mine without the need for any other software
DebbieLawson196
Quote from: ke1thd1an3
KeePass defaults to {USERNAME}{TAB}{PASSWORD}{ENTER} for the auto-type options. You can change that for any special cases. I have quite a few of my entries set to {PASSWORD}{ENTER} so that I have to select the right field manually before using auto-type.
Fixes: 1,491
1password manages ok
bobpullen
Fixes: 327
As does LastPass.
