Curiosity about speeds
adamwalker
Fixes: 223
Re: Curiosity about speeds
why so many problems?
I can't really give you a straight answer to that I'm afraid, we just need to look into this further.
I had a message saying it was fixed.
I did spot that, it is back with our faults team so I'll make sure it gets looked at.
 Adam Walker
sixthprawn
Thanks again Wink
sixthprawn
It dc'd and got slower...
psd1959
Hey Sixthprawn, there spoiling you. http://www.speedtest.net/result/1303851867.png this is mine... it's up and down more times than a rabbit in the mating season.
psd1959
And just for a bit of continuity http://www.speedtest.net/result/1303912081.png ?
jelv
Fixes: 10
@psd1959
You've only made two posts on these forums in somebody else's topic and just showing bad speed test results - not very constructive!
If you want any advice I suggest you start your own topic giving some more information like your router stats, what speeds you normally get, the results of a BT speed test etc.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
adamwalker
Fixes: 223
@psd1959
Just to echo what jelv is saying, we're all here to help so do come back to me if you want some assistance through investigating the speed issues you seem to be mentioning.
 Adam Walker
sixthprawn
You can lock this topic now, moved on. Got better ping and speed elsewhere on the same line, funny that. Thanks to those who tried to help me out, unfortunately wasn't meant to be.
jelv
Fixes: 10
Another BT provider or LLU?
sixthprawn
Bt for now, llu after a phone call Smiley
adamwalker
Fixes: 223
As I mentioned before, sorry to hear that you've gone. Hope everything goes OK for you.
All the best,
Adam
 Adam Walker
